Found a BROKEN VALVE SPRING
So i opened up my B16A Motor.
Disassembled the Head.
Taking off the valve springs so i could replace the valve seals.
I Found a BROKEN Valve spring.
Luckily for me nothing happened to the motor.
What Could cause a valve spring to break?
Also would this cause low/lower compression in one cylinder?
Re: Found a BROKEN VALVE SPRING
fatigue over time or possibly imperfections will make them break. Also it Will lower compression if its hanging a valve open. Might have a bent valve now.
Mr. Badwrench
i personally have never seen one on a b. i know it has happened, just no 1st hand exp on my part. now on 3.8 gm motors all the time.
yes it can cause low compression in a cylinder
