OK with CEL on all the time?
Old 12-08-2002, 09:08 PM
Troy's Avatar
Default OK with CEL on all the time?
Im running a SOHC Greddy turbo kit with a test pipe. Since I didnt make a second O2 hole for the sensor, Im getting the CEL all the time.
Question, should I just leave it like that and nothing would go wrong if I do oil change rountinely and use only 91+ octane? Or would the CEL affect performance and damage my motor/transmission?
Old 12-08-2002, 09:13 PM
T-sohctec's Avatar
Default Re: OK with CEL on all the time? (Troy)
Nah it woln't damage anything except make your car run like ****. There are actually things you can do to fool your secondary O2 sensor "see" perfect A/F ratios.
I'll try and Find a link for you.
CzanSOHC's Avatar
if you always have a cel, you will never know if you get another one..if that makes sence.
or you can buy a O2 simulator.
Old 12-08-2002, 09:26 PM
T-sohctec's Avatar
Default Re: OK with CEL on all the time? (CzanSOHC)
Ahh fuggit I can't find you a direct link, but yeah you can fix it with an O2 simulator without too much effort.
Good luck
DumpedSi
08-20-2003 07:06 AM
comptechgsr2000
04-26-2002 09:02 AM
Quick Reply: OK with CEL on all the time?
