... engine eats coolant
Old 10-10-2002, 12:03 AM
1.8T_EG's Avatar
Default ... engine eats coolant
... does this happen to anyone else?... i fill my overflow reservoir tank to about an inch below the max line... then in about a week (sometimes less), the coolant is below the min line again... some notes: this only started happening after i started boosting and i have never over-heated and the stock temp gauge rarely goes past the halfway mark... also, i never find any coolant leaking below my car... so wtf is going on?... anyone have any thoughts?... lemme know... thanks...
Old 10-10-2002, 12:12 AM
Cramerox's Avatar
Default Re: ... engine eats coolant (1.8T_EG)
Someone had this problem before- they had a sleved block and the coolant was seeping under the sleves..causing the coolant to get burt up...something like that.
Im not sure if ur block is sleeved.
Old 10-10-2002, 06:57 AM
1.8T_EG's Avatar
Default Re: ... engine eats coolant (Cramerox)
... no sleeved block here (maybe this winter)... i have a stock block with everything else in the sig...
... also, i just noticed that my overflow tank is not bolted down to anything... should it be?... right now, it just kinda balances on the stock radiator fan... lemme know... thanks...
[Modified by 1.8T_EG, 12:25 PM 10/10/2002]
Old 10-10-2002, 10:47 AM
Colton Grundy's Avatar
my old moter did that all it was is blown head gasket.
Old 10-10-2002, 11:35 AM
SyndicateEH's Avatar
Default Re: ... engine eats coolant (derrickcxhatch)
my hatch does it. . . i put it down till i pull the motor for a rebuild. . it's the head gasket
Old 10-10-2002, 11:40 AM
rioninja's Avatar
headgasket.
Mr.Death
07-17-2008 04:38 PM
arizo
15
02-02-2008 03:07 PM
93(Civic)EG6
11-08-2006 08:48 AM
george34
05-07-2006 07:09 AM
XxslayerxX
27
10-19-2003 11:33 AM
Quick Reply: ... engine eats coolant
