Engine build help **cylinder wall scarring** 56k maybe
Old 03-28-2006, 05:44 PM
turbo sol's Avatar
Default Engine build help **cylinder wall scarring** 56k maybe
Well I took my block (d16z6) to the machine shop to hone out for my new SRP pistons (std bore) they said I would be ok with the required piston to wall clearance with out going with oversized pistons.
after i got the block home and cleaned it up I noticed scarring around the top of the cylinder walls. the shop said something about it when I picked it up and thought it would be ok to use. (didn't make sense at the time) now it looks like my top ring is going to set in the grove. They couldn't take off anymore with out it being too loose. If I could avoid buying another set of pistons that would be great, if not its still cheaper than sleeving. thoughts?
they look like where the rings used to sit. They aren't machine marks are they? I didn't notice them before the block was honed.
the pics:
Old 03-28-2006, 05:50 PM
Newt Dog's Avatar
Default Re: Engine build help **cylinder wall scarring** 56k maybe (turbo sol)
The last picture scares me..
Old 03-28-2006, 05:52 PM
turbo sol's Avatar
Default Re: Engine build help **cylinder wall scarring** 56k maybe (Newt Dog)
i agree that is the worst one. I cant believe that I would have missed that. I had 3 block to choose from and I picked the one with the best walls. thats why i thought it might be a machining error?
Old 03-28-2006, 05:53 PM
earl's Avatar
Looks like your rings were rusted to the cylinder wall at one time. You will have a smoking engine with bad compression if there is an indentation along with the marks on the wall.
Old 03-28-2006, 06:07 PM
turbo sol's Avatar
Default Re: Engine build help **cylinder wall scarring** 56k maybe (earl)
there is def. an indentation that last one is nasty. looks like I need to get bigger pistons.
crappy. just when I thought I was gonna get things going on the rebuild.
well at least I found it out before I put anything together. thanks guys.
anyone need stock SRP d16y8 pistons 9:1 (never been used!)
Old 03-28-2006, 06:20 PM
drintegra's Avatar
pu tthe pistons up on the market place and rebore and hone the walls bigger to take that out, although that looks pretty deep. Surprised the machine shop let you walk out with that
Old 03-28-2006, 06:38 PM
turbo sol's Avatar
Default Re: Engine build help **cylinder wall scarring** 56k maybe (drintegra)
yeah I am pretty pissed, safe to say I wont be going back to them.
it's just fustrating b/c I have been getting pieces here and there for over a year now, now I have to keep looking. At times I don't think this motor will ever get built
Old 03-28-2006, 07:13 PM
gnar kill's Avatar
D series blocks are pretty easy to fing I would almost suggest tryin to get a new block......might be cheaper
Old 03-28-2006, 07:26 PM
raiden571's Avatar
i got a bare z6 block if u want it. shipping is gonna be a lil expensive, but cheaper then buying new pistons
Old 03-28-2006, 07:27 PM
urbansi's Avatar
Default Re: Engine build help **cylinder wall scarring** 56k maybe (gnar kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">The last picture scares me.. </TD></TR></TABLE>
Yeah either bore .20
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gnar kill &raquo;</TD></TR><TR><TD CLASS="quote">D series blocks are pretty easy to fing I would almost suggest tryin to get a new block......might be cheaper</TD></TR></TABLE>
Yeah its not worth using something that may cause problems expecially when d-series motors are pretty easy to get, it will most likly be easier to get a new block and just have it re-machined then buying new pistons...
Old 03-28-2006, 07:41 PM
turbo sol's Avatar
Default Re: Engine build help **cylinder wall scarring** 56k maybe (urbansi)
I'll have to have another shop check out my other block to see if its usable. I have a y8 block too, myabe I should just use that, but I wanted to use the z6 block and y8 head. good thought guys.
Ryhaz
10
01-14-2014 07:57 AM
flatblackintegragsr
02-24-2008 10:52 AM
B-B-K
08-09-2005 09:01 PM
TurboSC
07-23-2005 08:44 AM
AgentJam
07-22-2004 06:22 PM
Quick Reply: Engine build help **cylinder wall scarring** 56k maybe
