Edelbrock Performer x VS Victor x - Honda-Tech
Old 02-29-2012, 02:21 PM   #1
Broertje's Avatar
Default Edelbrock Performer x VS Victor x
Which one do ya'll recommend? I heard victor is more ofr the mid range, and performer for top end. And not to mention the fact its $100 cheaper.
Which one is preferred and why?
Broertje is offline   Reply With Quote
Old 02-29-2012, 02:29 PM   #2
thegatekeeper14's Avatar
Default Re: Edelbrock Performer x VS Victor x
I run a fully ported and polished victor x from Renown Performance. How ever i would like to see the performer x and what it can do. Heck contact Renown and have them port one for you.
Also your gonna wanna share your set up so we can accurately suggest a quality performing manifold for you.
thegatekeeper14 is offline   Reply With Quote
Old 02-29-2012, 03:12 PM   #3
Broertje's Avatar
Well I havent put a solid setup together, but its gonna be Boosted, +/- 300 WHP.
Old 02-29-2012, 03:26 PM   #4
lsturbo33's Avatar
For 300 just use a stock manifold.
lsturbo33 is offline   Reply With Quote
Old 02-29-2012, 03:44 PM   #5
joe b's Avatar
Anything less than 500whp and its a waste !!! Trust me i know !! Stock will be more than sufficient for up 450 whp .
joe b is offline   Reply With Quote
Old 02-29-2012, 04:05 PM   #6
m3tech95's Avatar
Longer runners=lower rpm power increase
Larger Plenum=higer rpm power increase
If your only revving to stock or 8,200 rpm, go with the Performer X = Power-band 4500-8200
"The Performer X intake manifolds for Acura and Honda's are engineered for street/strip applications where peak torque and horsepower gains are realized between 4500-8200 RPM. The larger-than-stock plenum volume and 9" runner length are tuned for producing peak power at high RPM."
If your going to be revving to 10,000 rpm go with the Victor X = Power-band 7000-10,000
"Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance, this manifold has four additional bosses for nitrous or added fuel injectors"
This is regardless of if your turbo or N/A that's what range they were designed for. Hope this clears up some confusion about the difference in these two manifolds.
m3tech95 is offline   Reply With Quote
Old 02-29-2012, 06:05 PM   #7
I have the JG Eddlebrock intake mani on my turbo application. Does anyone know if this is the Vector X or Performer X?
DarryCar is offline   Reply With Quote
Old 02-29-2012, 06:13 PM   #8
It is the victor x.
DraginX is offline   Reply With Quote
Old 02-29-2012, 07:15 PM   #9
Turbo-LS's Avatar
Op aftermarket manifold will increase over stock, perform will be suitable for stock redline and the power your looking for. Victor is for larger turbo and power goals
Turbo-LS is offline   Reply With Quote
Old 03-01-2012, 03:26 AM   #10
Broertje's Avatar
Ok thanks everyone, these manifolds cost like $300-400. How much gain will i get over stock AVG? Are we talking like minimal gains due to 300whp or
Old 03-01-2012, 04:50 AM   #11
LS AzZkIkr's Avatar
Under 500hp = skunk2, AEBS, stock
Over 500hp = victorX, Magnus, golden eagle
Just my $.02
LS AzZkIkr is offline   Reply With Quote
Old 03-01-2012, 05:59 AM   #12
Turbo-LS's Avatar
300whp is 300whp. if might give you a little more low end and mid range power but stock will work fine for 300
Old 03-01-2012, 06:52 AM   #13
Broertje's Avatar
Ok thanks
Old 03-05-2012, 07:09 PM   #14
Quote:
Originally Posted by DraginX View Post
It is the victor x.
Thanks. All it says on it is JG Edlebrock on it. I have had it for a while and just forgot which one I had. It worked great when I had 384whp and it still flows great now at 515whp. Hoping it will still flow good at 600+. Good mani for the price.
performer X , skunk2 pro series OR VICTOR X ??? pithor-c1 All Motor / Naturally Aspirated 2 07-12-2012 08:15 AM
itbs or victor x mygoldeneg Want to Buy 12 01-20-2012 07:53 PM
WTT: performer X for a victor X -- GSR red civic standard For Sale 5 02-09-2011 07:37 AM
Intake Manifold IgnitionZ055 Acura Integra 5 11-17-2008 05:35 AM
Intake Manifold for B18B1 engine... MansuDC2 Acura Integra 11 08-02-2005 06:20 PM
Tags
acura, difference, edelbrock, eldibrock, good, hondatech, intake, integra, kit, manifold, performance, performer, porting, renown, turbo, victor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
