Turbo options for D16Z6 with AC & PS?
I have a 1992 Civic Sedan with a d16z6 and am looking to do a small rebuild(not a complete motor overhaul) and turbocharge it. What are my options for Turbo setups/kits to keep it as a good daily?
This is a picture of my motor.
Moderator
Re: Turbo options for D16Z6 with AC & PS?
There are only a couple of vendors left that specifically have pre-fabbed retrofit turbokits of any quality. One of them is Go-Autoworks. You can find them online and check out their options.
Please avoid eBay-based companies like JDM Sport, SSAutochrome (or similar) or other companies of similar material.
Ensure that the engine is of good mechanical status (no leaks, smoking, compression test, etc, before considering such a build.
Also you can check the FAQs highlighted in Grey at the top of the forum. They give you step-by-step components list as to what you need.
When you have specific questions on your build, you can start a new thread. Please make sure it has an appropriate title so that anyone reading can understand what you're asking.
Avoid posting the same thread in multiple forums.
Welcome to H-T. Where the weak and humble are eaten alive!
