eagle crankshaft in b18 block? thrust washer or bearing problems?
Old 07-10-2006, 05:45 PM
b18sihatch's Avatar
Default eagle crankshaft in b18 block? thrust washer or bearing problems?
i was told that the oem crankshaft has 2 different bearings and that if you use the eagle crankshaft will bind up and not spin is this true?
Old 07-10-2006, 05:52 PM
non-VTEC's Avatar
Default Re: eagle crankshaft in b18 block? thrust washer or bearing problems? (b18sihatch)
whoever told you that has no idea what they are talking about.
you need to select the proper size bearings/thrust washers for the the proper clearances no matter which crankshaft you use.
Old 07-10-2006, 05:55 PM
NJIN BUILDR's Avatar
If the clearance is correct the eagle crank will fit and spin just like the oem.
Old 07-10-2006, 06:06 PM
b18sihatch's Avatar
Default Re: eagle crankshaft in b18 block? thrust washer or bearing problems? (NJIN BUILDR)
what do you guys think of a eagle 95mm crankshaft
the block is a 84mm darton pro sleeve b18a1
with a 89mm crankshaft it will be 2.0 with the 95mm it will be alot larger
what kinda pistons do you need to run a larger stroke crankshaft
Old 07-10-2006, 06:13 PM
non-VTEC's Avatar
you need custom length rods (unless eagle makes rods already for the 95mm crank?) and you might also need some custom pistons with the piston pins in diffrent locations.
Old 07-10-2006, 06:32 PM
b18sihatch's Avatar
Default Re: eagle crankshaft in b18 block? thrust washer or bearing problems? (non-VTEC)
do you guys think that the eagle h beam rods are pretty good? if i upgrade the rod bolts?
also so i can use the eagle crankshaft ... they said sumthihng like the washers for the oem crankshaft have 2 different sizes but the eagle doesnt have 2 different sizes so it binds up and doesnt want to spin
Old 07-10-2006, 06:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">do you guys think that the eagle h beam rods are pretty good? if i upgrade the rod bolts?
also so i can use the eagle crankshaft ... they said sumthihng like the washers for the oem crankshaft have 2 different sizes but the eagle doesnt have 2 different sizes so it binds up and doesnt want to spin</TD></TR></TABLE>
The Eagle rods come with 3/8" arp 2000 bolts which will be fine unless its a 8 second car.
And I have no idea what you/they are talking about as far as the thrust washers.I would call 'them" back and see if they can clear it up.
Old 07-10-2006, 07:04 PM
b18sihatch's Avatar
they the local race shop said this and i quote
the eagle crank goes not like the b18a due to the thrust washers. the oem crank has 2 different sized thrust washers, the eagle crank does not, therefore causing the crank to bind up & not spin.
make any sense at all?
Old 07-10-2006, 07:13 PM
[QUOTE=b18sihatch] make any sense at all?[ /QUOTE]
Nope
Old 07-11-2006, 05:40 AM
b18sihatch's Avatar
anyone else?
Old 07-11-2006, 08:27 AM
earl's Avatar
I agree with NJIN. Find another shop as those guys seem clueless.
If this is for a turbo build, just use an oem crank. You will make more power than you can use with that crank anyway. Save your money for a large turbo.
Old 07-11-2006, 09:12 AM
RyanEJ8's Avatar
Default Re: eagle crankshaft in b18 block? thrust washer or bearing problems? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I agree with NJIN. Find another shop as those guys seem clueless.
If this is for a turbo build, just use an oem crank. You will make more power than you can use with that crank anyway. Save your money for a large turbo.</TD></TR></TABLE>
I agree with Earl. OEM crank is all you need with an FI build.
Mutiny1
02-13-2010 04:26 PM
GoldLudeRay
09-13-2008 03:51 AM
Bc3
12-26-2006 11:35 AM
PUSHER
01-10-2004 11:38 AM
EKweezy
10-08-2003 10:09 AM
Quick Reply: eagle crankshaft in b18 block? thrust washer or bearing problems?
