diy turbo set up - searched for it already... - Honda-Tech
Old 10-25-2001, 07:27 AM   #1
New User
twizt2's Avatar
Default diy turbo set up - searched for it already...
hey there
newbie here. been visting the board for a while and i'm looking to participate. got a question: if I do a non-intercooled turbo set up initially and decide later to go with a intercooler do I have to remount the turbo so that the exit side of the turbo is closer to the driver side so that piping can enter the intercooler and exit on the t-body side? Any help would be appreciated especially by some resident diyer and fellow junk yard junkies.
thx - twizt
twizt2 is offline   Reply With Quote
Old 10-25-2001, 09:03 AM   #2
TurboInteg95's Avatar
Default Re: diy turbo set up - searched for it already... (twizt2)
you wont haev to remount the turbo, you may have to spin the compresor housing around a tad depending on your setup. You will definitely need to make new piping.
TurboInteg95 is offline   Reply With Quote
Old 10-25-2001, 09:36 AM   #3
New User
twizt2's Avatar
Default Re: diy turbo set up - searched for it already... (TurboInteg95)
turbo- so if the compressor side is facing towards the passengerside what path does the tubing take to from the turbo to get to the intercoller and then to the throttle body?
Old 10-25-2001, 10:18 AM   #4
New User
Same deal regardless of which side the comp is on - down and 90 degree bend, follow teh radiator to the driver's side fender, wrap around the bumper support to the front and into the intercooler.
dbman96 is offline   Reply With Quote
Old 10-25-2001, 11:09 AM   #5
New User
twizt2's Avatar
Default Re: diy turbo set up - searched for it already... (dbman96)
that just seems like a convuluted path. screw it. I'll just go ic from the get-go and be done with it. Thanks for the input.
d15b engine harness? twizted-myatt Honda Civic / Del Sol (1992 - 2000) 4 07-16-2011 02:44 PM
jdm d15b into 96 civic twizted-myatt Honda Civic / Del Sol (1992 - 2000) 51 05-29-2011 08:36 AM
97 Civic sputters at 2-3K rpms twizted-myatt Honda Civic / Del Sol (1992 - 2000) 31 05-25-2011 03:55 PM
FS: Stock intercooler from Galant VR4 tampaSi Classifieds: Forced Induction 10 05-23-2003 06:50 AM
DYS turbo kit for D series (partially complete) Spaceballsthelunchbox For Sale 8 09-02-2002 06:04 PM
Tags
diy, gsr, honda, intercooled, setup, tech, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
