Discussion Topic: Tell us about your favorite turbocharger and why - Page 2 - Honda-Tech
Old 08-22-2015, 01:14 PM   #26
Geis's Avatar
Default re: Discussion Topic: Tell us about your favorite turbocharger and why
Uhmm
Thanks for the lessons guys but I was already aware of the difference and have seen the maps on top of each other, easy to tell the difference
However, I got it with a full race kit I bought off a member here, and with the ramhorn mani I'm hoping to get around 300whp, or should I just sell it and get a 50trim?
Geis is offline   Reply With Quote
Old 08-22-2015, 02:09 PM   #27
Who is Mr Robot?
wantboost's Avatar
<p>You'll be fine with the turbo you have now.&nbsp;</p>
wantboost is offline   Reply With Quote
Old 08-22-2015, 02:36 PM   #28
Geis's Avatar
Quote:
Yeah I'm honestly debating if i want something that spools that quickly.
Old 08-22-2015, 04:16 PM   #29
Moderator
TheShodan's Avatar
Quote:
It won't with a Full-Race kooks manifold. Really, you'll be close to the surge limit anyway. Those can't do more than 320whp at over 20psi or so.
TheShodan is offline   Reply With Quote
Old 08-22-2015, 06:48 PM   #30
Geis's Avatar
Quote:
Just because it's a ramhorn it'll slow the spool by THAT much?
I mean, seeing the size of the turbo, it being ball bearing and running of a 2l as opposed to 1.8 and all
Old 08-22-2015, 09:18 PM   #31
Moderator
TheShodan's Avatar
Yep.. It's called exhaust VOLUME, vs, proper exhaust VELOCITY.
Big manifolds with damn near 2" OD runners with a tiny responsive turbo really don't mix for the best behaviors.
Old 08-23-2015, 11:19 AM   #32
Geis's Avatar
Awww your almost making me not want it :<
I dunno depending on resale value and all we'll see what happens. It apparently had been sitting for a long time so it has a tiny bit of shaft play, anything you suggest me doing before using it on my setup?
Old 08-23-2015, 12:05 PM   #33
B20VtecVillain's Avatar
It's never done! It's never fine! Never leave it alone! Lol.
Anyways as was said above, hard to choose any one turbo as a "favorite" but for 250-300hp The old disco potato Gt2860rs is king for me. For 350-450 I love the Billet wheel GTx3076r, for the 500-600 realm I loved the billet wheel 6262 or some of the beefier gt35r variants. For huge all out power if I was building a super 1000+hp Stroker K I'd probably chose a billet Turbonetics 7675
B20VtecVillain is offline   Reply With Quote
Old 08-23-2015, 01:10 PM   #34
LightningTeg's Avatar
The Greddy 18G was my first turbo. It was cheap, reliable, and made good power on my stock LS. Not really a whole lot to say, it was my first turbo so I was excited to just be boosted lol
The GT2560R replaced it and was on the stock LS for a couple years. It was probably my favorite turbo for a daily honestly. "instant" spool from pretty much any rpm above 3000. Just punch it and it goes. No need to brake boost when racing, and was great for autocrossing. I had a buddy who normally does time attack EVO's (Professional Awesome is the team) drive it one round and said it was the most fun hes had autoxing a honda. I would do it again in a heartbeat if I was to build a stock LS turbo again.
SC6152E was on the built LS I had in my EJ8 for a year or so. It was fairly old and had started to burn oil already when I bought the car, but put some solid numbers up with the motor prior. Not super responsive but didnt feel huge. Didnt really have it very long to say whether or not how much I liked it.
(gen I?) STC reaper wheel was retrofitted on the SC6152E when I had it rebuilt and lasted up until recently. The compressor wheel felt more responsive and definitely had some better top end. This all of course was still in the original packaging with the non ported shroud compressor housing. I was pretty happy with it for a highway car. Ended up making 602/453 on 30lbs of boost with the built LS
The STC Interceptor is what I have now. It spools about 750 rpm quicker with the VTEC Head than the LS setup with the reaper. It sounds orgasmic spooling up with the HKS style compressor housing and made really nice torque, which was what I was after replacing the reaper. I've really only had it for a little while but so far Its been great. The recovery spool between shifts is noticeably better than the reaper (ball bearing also)
LightningTeg is offline   Reply With Quote
Old 08-23-2015, 01:21 PM   #35
Moderator
TheShodan's Avatar
Turbos don't get old like meat.. Just prime it, get an inline oil filter for it, and go to town.
Old 08-23-2015, 04:09 PM   #36
Who is Mr Robot?
wantboost's Avatar
The 18G is a very capable compressor wheel. The only issue is that the most common Honda version is Greddys TD05H-18G. On a high VE application B series motor the TD05 compressor cover and turbine wheel don't allow full use of the compressor wheel. D series motors are making 350+ with ease with that wheel combination while B series struggle to reach the same goal.
Had the B series application used a TD06 compressor cover it would have behaved a bit better but it's the small TD05H turbine wheel that ultimately restricts power. A slightly larger TD06 variant in the same turbine housing would allow the full flow of the compressor wheel to be utilized and it would have made the B series kits serious performers. Personally I've wanted to build this version of an 18G and see just how much better it would perform over the typical TD05H-18G
Old 08-26-2015, 01:17 PM   #37
Screw you guys, I'm... going... home.
tjbizzo's Avatar
... <p><img src="http://cimg9.ibsrv.net/gimg/honda-tech.com-vbulletin/450x600/80-image_c49c497c37c744433324c1050c51d7e29c6702a4.jpg " title="" /><br />...</p>
60mm 62 trim
Would someone please be kind enough to explain to a noob like me why these two apparently identical compressors have such different maps? TIA!
tjbizzo is online now   Reply With Quote
Old 08-26-2015, 08:58 PM   #38
Moderator
TheShodan's Avatar
Quote:
Adiabatic efficiency points were just smoothed out in the mathematical extrapolation.
Kinda like statistics with a little pre-calculus... you have points in a sample, and when connecting all the dots with a line, you had the standard deviations change a bit to give a more accurate sample.. So the lines change.
Same result, no change in power, just, more precise calculation. Nothing more, nothing less.
I think I found a new favorite. Frank M's Interceptor R+
Old 08-27-2015, 01:41 AM   #39
extended tip
ls joker is offline   Reply With Quote
Old 08-27-2015, 01:50 AM   #40
riceball777's Avatar
for 600-650whp I love my garrett gtx3576r
riceball777 is offline   Reply With Quote
Old 08-27-2015, 06:23 AM   #41
Billet borg warners, best cost-performance in the market by far
SalvadorSZ is offline   Reply With Quote
Old 08-29-2015, 06:16 PM   #42
Moderator
TheShodan's Avatar
One of my other All-Time Favorites. GReddy T78-33D. RX-7s were all over this for years.
Or the GReddy T78-29D
Old 08-30-2015, 02:57 AM   #43
Who is Mr Robot?
wantboost's Avatar
If I had to pick one out of my personal "collection" of 23 it would have to be my IHI RX8.
Why?
Because it's 25,000 dollars and 15.8lbs of ball bearing titanium and magnesium Motorsports history and capable of supporting around 1200hp.
Old 08-30-2015, 03:33 AM   #44
second time this week ive heard or read something bout titanium in turbos, titanium wheels
Old 08-30-2015, 03:37 AM   #45
yea thoughs were popular on the big liter cars
Old 08-30-2015, 04:50 AM   #46
Who is Mr Robot?
wantboost's Avatar
Yea the RX8 uses a PTFE coated titanium compressor wheel in a magnesium compressor housing. There's some debate as to the turbine housing material as it's a very thin wall (around 2.5mm throughout) investment casting which is super light. It weighs less than a Garrett GT28 T25/5 bolt internal wastegate turbine housing and is 4 times the size lol.
Granted at the level of racing this turbo was used at cost obviously wasn't an issue, only making power and being fast but consistent.
Old 10-28-2015, 09:00 PM   #47
Moderator
TheShodan's Avatar
Old 10-28-2015, 09:10 PM   #48
theYBLEGAL's Avatar
Ohhh, billet anodized blue anti-surge goodness.
And for wantboost's post, is that your billet GTX30 wheel I see there?? :D Looks mighty familiar (got mine too, waiting on the ATP ported shroud).
Wish I was deeper in the industry, or ballin enough to have Tial v-band turbine housings and 25,000 turbos lol. For now, stayin vicarious.
theYBLEGAL is offline   Reply With Quote
Old 10-28-2015, 09:28 PM   #49
Moderator
TheShodan's Avatar
This is nothing like a GTX30 compressor wheel.. Even the blade number and style should tell ya something is different. GTX30R is an 11-single blade design. This is not
Wantboost is more of a connoisseur and collector of snails.. Not ballin', just selective of what he's had over the years
Old 10-28-2015, 11:50 PM   #50
Who is Mr Robot?
wantboost's Avatar
One is a demo wheel KTS gave me, it's not a full wheel.
The other is a BorgWarner/Bullseye ETT Billet wheel I've had for close to 8 years now. I never found a turbine with a big enough shaft diameter to use it.
My current collection sits at roughly 23. It's just years of looking for things and getting lucky plus people have given me turbos.
A few I picked up because I found the way they failed to be atypical so I tore them down to find out what had happened. 1 was a gt1752 that ate a compressor wheel and cracked a backplate and then 2 IHI VF39s were given to me that came off the same STi which murdered the entire bearing assembly and both shafts (told them to check the feed line, it was blocked lol)
As far as being given turbos. They would be a GT2871R, FP TD06SL2 20G, 2 60 trim T3s, a GT2860R, and a Switzer 3LM.
Other than that it's things like an STC turbo, Evo 8 16G w/ FIA 32mm restrictor, IHI RX8, HE351VE, GT3788VA, a pair of JWT Sport 600s, two t25/t28 hybrids, Stock SR turbos, and so on.
7 are lined up for my project cars, at least this version of each. Once a few are shaken down they will get different turbos from STC. Some are going to get rebuilt/modified and sold. I'm always looking to add though. I've stumbled upon a mythical Holset HX50R from the Lola/Cosworth XB CanAm cars I'm trying to get my hands on. Possibly an HX35 for a BS project.
I basically self educated myself on everything turbocharger related which got me where I am today lol. I start an IndyCar/LeMans program next year if nothing goes wrong so hopefully in the next two years I'll be getting paid for everything I know. Yay for hard work and dedication.
Your Favorite NSX!!! fknfast Acura NSX 380 02-28-2017 07:24 PM
What was your best/favorite purchase in 2015 __oversea General Discussion and Debate 56 01-02-2016 09:55 PM
Least Favorite car MXPX General Discussion and Debate 37 07-23-2015 10:58 PM
what's your favorite feature or accessory? VeeSykkz Honda Accord & Crosstour (2003 - Current) 0 06-07-2015 09:33 AM
Favorite "Yo Momma..." Joke nightryder21 General Discussion and Debate 8 11-11-2003 04:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
