Piping question for turbo.....help
Old 03-02-2003, 05:04 PM
Rhythm Racer's Avatar
Default Piping question for turbo.....help
Hey h-ters as we speak i have 2.5 inch piping when i get turbo should i change it to 3 inch ............i herd 3 inch takes away low end torqe thanks
Old 03-02-2003, 06:42 PM
BlueSi2k's Avatar
Default Re: Piping question for turbo.....help (Rhythm Racer)
The bigger the better for turbo...3 inch is fine.
Old 03-02-2003, 07:01 PM
avividmemory's Avatar
Default Re: Piping question for turbo.....help (BlueSi2k)
depends how much boost you plan on running, if its low boost a 3" wont help you all that much, but the more you put into it the more its gonna help...
make sense?
Old 03-02-2003, 07:12 PM
fsp31's Avatar
Default Re: Piping question for turbo.....help (SpoolinLS)
I got this from a post awhile back from a Garrett engineer. Here's my "cliff notes"...
Depends on the size of the exhaust outlet on your turbo. If it's 2.5" (like a T4), then stick with the 2.5" DP and flare it out to 3" a little ways down as gradually as possible. If you connect a DP with a significantly larger diameter than the exhaust housing on the turbo, it can actually create a pressure wave. The exhaust is coming out of the turbo at high velocity and suddenly it expands into a larger space. When the exhaust expands, it slows down and the exhaust exiting the turbo behind literally "runs" into it.
Old 03-03-2003, 08:30 AM
thanks guys
Old 03-03-2003, 10:05 AM
LS-hatch's Avatar
If your talking about exhaust, yes, if you mean charge piping bigger is not always better. The bigger the pipe, the more lag you will have. Depending on the size of your turbo and how much boost your running, different sizes will be more efficient than others.
[Modified by LS-hatch, 2:06 PM 3/3/2003]
Old 03-03-2003, 10:24 AM
BlueSi2k's Avatar
Default Re: Piping question for turbo.....help (LS-hatch)
Yes but he said hes got 2.5 now...i dont think hed have charge piping with no turbo. Hes talking about exhaust
Serdar
11-18-2003 06:26 AM
Lost Type R
05-18-2003 12:28 PM
yisoulja
11-26-2002 06:54 PM
turbogsr13z
09-27-2002 12:26 PM
b18cTurbo
02-26-2002 06:41 PM
Quick Reply: Piping question for turbo.....help
