crower 404's good for turbo? - Honda-Tech
Old 01-26-2009, 12:57 PM   #1
Default crower 404's good for turbo?
i have an ls turbo stock internals and was plannin on gettin the crower valve train but not sure which cams any suggestions
sonne_side is offline   Reply With Quote
Old 01-26-2009, 04:40 PM   #2
racebum's Avatar
Default Re: crower 404's good for turbo?
smaller cams generally work better with turbo cars. 404s are NA high compression cams. call dave down at crower and have a talk with him & explain your goals. while cams are helpful on a turbo car, the tune and properly installing the turbo kit are your first priorities.
racebum is offline   Reply With Quote
Old 01-26-2009, 08:11 PM   #3
AMLS4dr200whp's Avatar
bigs cams help ls turbo setup I would recommend jg303s see my sig. JG 303s got better low end than 404s
AMLS4dr200whp is offline   Reply With Quote
Old 01-26-2009, 11:25 PM   #4
Glove's Avatar
i think the highest horsepower LS guy used 404's on his setup.
I just bought a set and im gonna put them in a couple weeks to see how they perform.
Il post a thread on them once im done.
Glove is offline   Reply With Quote
Old 01-26-2009, 11:40 PM   #5
92civiceg9gsr's Avatar
Yeah their prolly not as good as turbo specific cams but an LS needs help breathing so they'll perform better than stock cams. Not to mention that 404's sound great.
92civiceg9gsr is offline   Reply With Quote
Old 01-27-2009, 06:28 AM   #6
Wopsicle69's Avatar
I have 404's in my turbo LS, theyre absolutely SICKKKKKKK!!!!!!! Never tried anyone elses cams but the 404's work!!! I made 370 whp on 14psi on a t3/t67 and then cracked the stock piston ringlands. The block was bone stock as well. Wouldnt have an LS any other way!!!!! And the idle is dangerous http://ca.youtube.com/watch?v=1qDj3OLz4K0
Wopsicle69 is offline   Reply With Quote
Old 01-27-2009, 11:32 AM   #7
Glove's Avatar
jesus, you need to get that idle tuned properly
Old 01-27-2009, 02:52 PM   #8
HiProfile's Avatar
Big cams with tons of overlap will do that, no matter who tunes it. They aren't like vtec cams, where the lowcam has much less overlap. Look into 'vtec killers' and other cars w/o any sort of timing advance system, they lope just the same at idle.
HiProfile is offline   Reply With Quote
Old 01-27-2009, 04:11 PM   #9
i ♥ snails
quicksilver1689's Avatar
with cam gears you can give the motor what it wants depending on your turbo/manifold setup/EMP
quicksilver1689 is offline   Reply With Quote
Old 01-27-2009, 06:45 PM   #10
Glove's Avatar
Quote:
thats what i mean.
reduce overlap, increase idle rpm.
would be much smoother.
he's idling at 600 it looks like.
Old 01-27-2009, 07:30 PM   #11
nonvtecallmotor's Avatar
I ran the 404's in my car as a daily driver. It idled near stock and made ~400whp on pump gas at like 15psi. Its all about the tune when making the car idle. My car went 11.5's on a 1.8 LS/ 404's on a 225 BFG a few years ago.
nonvtecallmotor is offline   Reply With Quote
Old 01-28-2009, 08:50 PM   #12
Glove's Avatar
Quote:
do you know what you had your cam gear settings at?
Old 01-29-2009, 02:42 PM   #13
Quote:
I tuned them on the dyno and no I dont remember or recommend using anyones settings. This was a set up that I had years ago.
Old 01-29-2009, 07:19 PM   #14
alpha's Avatar
I've done a few cars with 404's. They've worked great on every setup. I had a car with Crower 402-T making horrible power. Only thing I could think of was the cams. So he switched to 404's. Only thing that changed was dyno'd on different days. Same dyno, same correction, etc. With the 402-T cams the car made 450whp. With the 404 cams the car made 529whp with less boost. I had the dyno sheet posted a while back but had taken it down. I will see if I can dig it up
alpha is offline   Reply With Quote
Old 01-29-2009, 08:08 PM   #15
alpha's Avatar
After a lot of searching I found it. Runs were about two weeks apart. Same gear, same start rpm, etc.
Old 02-04-2009, 09:25 PM   #16
iNERtIA's Avatar
u guys know how 402T and 403 idles?
iNERtIA is offline   Reply With Quote
Old 02-04-2009, 09:35 PM   #17
dephtone's Avatar
I used to have Crower 62403's in my boosted b20 setup..Worked out VERY well, never got numbers but helped my b20 breathe up top where it usually lacks. I loved using them with my boosted setup. My 403s idled ~700 would drop down a little but not much.
dephtone is offline   Reply With Quote
gsr cp turbo pistons Crower 625 rods construct1 Mid-West (Sales) 5 02-10-2015 12:55 PM
turbo with crower 404s? jdmboy94 Forced Induction 5 06-19-2009 07:32 AM
Crower TurboEKcoupe For Sale 0 01-01-2006 07:06 PM
Crower Cams bcborn Tech / Misc 7 08-22-2005 12:48 PM
crower stage 3 cams for h22 acurafighter Honda Prelude 15 11-19-2003 04:54 PM
Tags
303s, 402t, 403, 404, 404s, b20, cams, crower, dyno, gear, jg, ls, settings, spec, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
