could it be my pcv system
Old 03-04-2009, 10:58 PM
pokmijn's Avatar
Default could it be my pcv system
ive been reading up on this a lot but cant seem to find my answer first off let me tell you what i have a b18a1 turbo no other mods...whole motor was rebuilt 10k miles ago with oem parts and added block guard.
problems i have is a little smoking it started smoking when the turbo went in. I have already replace the turbo just 3 days ago due to bad seal but the new turbo started smoking a little after two days of driving hit boost but never past 3 psi it smokes at idle and boost but not much just always the same amount. smoke is coming out my exhaust and my valve cover(from the breather) i dont have a catch can and my pcv system is not hook up to my intake manifold i just have it unplug so im thinking its because of the pcv because of the extra pressure being put in, would this cause the smoking.
sorry for the long post any help would be appreciated oh yeah I am tuned on chrome.
Old 03-05-2009, 09:25 AM
E85B18's Avatar
Default Re: could it be my pcv system
What color is the smoke? Are you sure your tune is good?
Old 03-05-2009, 12:21 PM
ll3o0sTeD's Avatar
weird... sounds like piston rings are letting oil thru...
Old 03-05-2009, 01:14 PM
srmofo's Avatar
time for a compression check....if they're low, add a little oil, and check em again....if they come up at all, your rings/ringlands are bad
Old 03-05-2009, 03:11 PM
ll3o0sTeD's Avatar
Old 03-12-2009, 11:56 AM
pokmijn's Avatar
took my car to the shop, turbo is good motor is good after compression and leak down test. Now the smoke only comes at idle for like the first 20 minutes then after that everything is good no smoke. My tune is good i have seen this guy tuned many turbo honda before.
what could it be im almost at the point where im gonna take everything off and run stock.
Old 03-12-2009, 01:14 PM
da_dude's Avatar
Sound like some bad valve stem seal.
Mattb16teg
11-13-2010 06:19 PM
TnC
03-30-2008 01:57 PM
kasso
09-08-2005 12:05 PM
igo4bmx
06-02-2003 06:54 PM
mracura
06-04-2002 09:17 AM
Quick Reply: could it be my pcv system
