TURBO stopped spinning! HELP!!! *PICS INSIDE*
Old 03-07-2006, 09:21 AM
mnlude's Avatar
Default TURBO stopped spinning! HELP!!! *PICS INSIDE*
Well, i decided that i want to rotate the center because the return fitting was on top. When i rotated, instead of just taking off the housing and setting it to my desire position, i rotated the the whole thing without taking off the housing. Which means that i also rotated the blue plate. On the third picture where you see two holes, those are the bolts i took off and then rotated it. Now it won't spin freely anymore. It still spins, only if i force it. Anybody know whats wrong?
Old 03-07-2006, 09:24 AM
Mag00n's Avatar
Default Re: TURBO stopped spinning! HELP!!! *PICS INSIDE* (mnlude)
what kind of turbo is that?
Old 03-07-2006, 09:31 AM
mnlude's Avatar
Default Re: TURBO stopped spinning! HELP!!! *PICS INSIDE* (Macan00n)
It's a Turbonetics T3 turbo i believe...
Old 03-07-2006, 09:50 AM
yee SERIOUS's Avatar
Location: The Village Hidden in the Leaves: Seattle, WA
you were suppose to loosen the bolts on the housing and just rotate the housing (compressor and exhaust side). that's how you clock the center. i think you took off the wrong bolts if you took off the ones on the center section....
Old 03-07-2006, 09:53 AM
Chip's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">you were suppose to loosen the bolts on the housing and just rotate the housing (compressor and exhaust side). that's how you clock the center. i think you took off the wrong bolts if you took off the ones on the center section....</TD></TR></TABLE>
Indeed. Move the backing plate and center housing back to where it was, and rotate the housings to get the oil return into the desired position.
Old 03-07-2006, 10:22 AM
sbiggi's Avatar
Default Re: (Chip)
Since you took the bolts off from the chra, it is possible you unseated the seal on the thrust assembly and it is binding on the back plate.
I would do like the others said and carefuly rotate it back so the holes line up. Also be carefull bolting it back up. If the seal/thrustbearing assembly doesnt seat correctly and you force it, you can bend the turbine shaft. (dont ask how I know )
Tippyman
06-01-2007 02:53 PM
pro547
06-20-2005 12:54 PM
delslo93
01-23-2005 12:31 PM
slowdx
09-28-2004 08:08 AM
Dawson21
06-06-2004 07:58 AM
Quick Reply: TURBO stopped spinning! HELP!!! *PICS INSIDE*
