Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: How to install supercharger kit
Step by step instructions for do-it-yourself repairs.
-->COMPLETE How-To:: Turbocharge Your Honda // Rep-ing Hypnotik Speed
#551
Re: -->COMPLETE How-To:: Turbocharge Your Honda // Rep-ing Hypnotik Speed
What a great write up, very informative, unfortunately the pictures are unavailablew and when I use the link you suggested I get nothing, any assistance would be great
#553
great post man but is all of that really necessary like the hacking of the injector clps they have to make some sort of upgraded plug n play 1s also I have a 94 integra obd1 so it should be easier to get some also I don't see every turbo Honda having those vacuum boosters either but anyway great writeup even tho its like 8 yrs old lol
#554
#557
Who is Mr Robot?
no, this thread is 9 years old and rarely gets looked at. Anyone who might have saved the photos is no longer an active member here
#558
#561
Hello there, very nice write up !
This is a very detailed tutorial which makes any body able to install this setup. Good job and thank you.
I love the vacum manifold. I wish I used this on my previous setups! Really Really Clean.
I have an OBD1 Integra, B18 B1 Engine and Hondata is on my ECU and it works.
For the wide band sensor, is it true that I can use pin D10 for better wide band accuracy since it supports 5 volts?
Also, if the statement above is true, do I have to cut the 2 resistors (R136 / R138) on ECU off to be able to do this? Or can a simply ignore this step and still use D10 ?
Also, where would I be able to download a base map to start tuning?
Im boosting 8 PSI, Walbro 250, 440 CC injectors, Any basemaps you can suggest to start ?
Thank you !
Thank you !
#562
Thank you ![/QUOTE]
Hi,
You can use the D10 for the wideband without issues. It will read between 10-18 AFR which is enough.
Also i have a S300 basemap for B18 turbo which you can try. Just post your email address.
Best regards,
Chris
Thank you ![/QUOTE]
Hi,
Best regards,
Chris
#563
Thank you !
Thank you !
Best regards,
Chris[/QUOTE]
Thank you! So, I can use D10 with out cutting the 2 resistors?
my email is thiagocosta85@hotmail.com
Thanks again !
#564
Hi,
Best regards,
Chris
Thanks again !
Best regards,
Chris
Thanks again !
Yes you can use D10 without cutting the resistors
I have sent you the basemap.Please let me know how it goes.
Cheers!
#565
Thank you so much !!! I did get it. The turbo is not installed yet, I will do it as soon as the temperature goes up a little though, and will load this map you gave me. Thanks so much !
Also, What's the best RPM for 2 step? Should I do fuel only, or fuel and timing cut?
#566
Honestly, D14 is easier as it does not require any additional modification. It will not read the full 5v range, BUT.,,, You will never see 5v anyways. If you're running that lean, your car is in trouble and HIGHLY likely to just die out anyways. FWIW, i've been running mine on D14 since initial install over a year ago and have not had any readings higher than 4v. Ever. Never had any issues specifically using D14 either.
I am running Neptune and Innovate LC2 wideband. Up to you Good luck with your build!
#568
#569
Moderator
It is gone. The original creator stopped their website. There are other write-ups (including Page 21 & 22) that may not be as complete as that one from Hypnotik, but they are there. It's just that even the parts lists have changed due to changes in technology, availability of different materials and different turbochargers. So, the ones out here may be more of a general write-up, and not as much of a Step-by-step manual instruction list as you would hope.
You can create your own thread on the FI forum if you'd like to inquire about installation how-tos, but you need to show what you've found first.
Curated Content Editor
Honda-Tech News
06-28-2019 02:45 PM
HondaPartWorld
12-27-2012 06:50 AM
