clogged pcv, oil seals, and oil leaks
Old 07-29-2004, 06:55 PM
1.8T_EG's Avatar
Default clogged pcv, oil seals, and oil leaks
okay, i've read through the archives and found that if you continue to run with a clogged pcv valve, you can cause excess pressure and blow an oil seal. which oil seal are we talking about here?
here's my situation, i noticed that i was leaking some oil. getting underneath the car, i narrowed down the source of the leak to the black box next to the oil filter where the pcv valve is (96 gsr). so i suspected a clogged pcv, and i was right. after replacing the clogged pcv valve with a new one, i was hoping that the leak would go away, but it looks like it is still leaking. so i was wondering if i blew an oil seal, but which one? where do i look to check? it still looks like the oil is leaking from that black box. is it possible that the black box is full and i just need to drain it? any other ideas or suggestions?
please help, thanks in advance.
Old 07-29-2004, 07:51 PM
Tad
Tad's Avatar
yo,
I had my valve breather tube kinked and it made the pcv valve(or where it mounts) squirt MAD oil allover.
anyhoo,
that "black box" is replaceable.
examine all the hoses in the pcv system, make sure they're not clogged or kinked,
make sure the black box isn't damaged.
or just replace it to be safe,
I dont think its very expensive.
its in a bit of an annoying spot to work in,
but better than driving around and risking your engine.
Old 07-29-2004, 08:34 PM
1.8T_EG's Avatar
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">yo,
valve breather tube? what is that? the tube going from the valve cover to the intake in a stock setup?
i agree it is in a PITA location, i plan on working on her this weekend, hopefully i can figure it out, thanks.
anyone else?
Old 07-29-2004, 09:29 PM
Tad
Tad's Avatar
Default Re: (1.8T_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8T_EG &raquo;</TD></TR><TR><TD CLASS="quote">valve breather tube? what is that? the tube going from the valve cover to the intake in a stock setup?
anyone else?</TD></TR></TABLE>
tube going from the valve cover to the intake yes,
it is connected to the pcv system.
Old 07-30-2004, 07:31 AM
1.8T_EG's Avatar
anyone else?
thanks
raverx3m
03-14-2015 10:12 PM
avotegra
09-04-2008 09:43 AM
andrew dc
05-04-2003 07:06 AM
pg_thao
05-21-2002 07:56 PM
Quick Reply: clogged pcv, oil seals, and oil leaks
