churches dyna pack vs raceline dyno jet. My results 60 less hp on the dyno jet
Old 11-14-2012, 11:15 PM
riceball777's Avatar
Default churches dyna pack vs raceline dyno jet. My results 60 less hp on the dyno jet
Church automotive testing here in so cal(Wilmington, ca) tuned my s2000. The car runs great but I just wanted to see what the car would do on a dyno jet. Churches dyno pack is always known to read higher than normal. My s2000 was tuned by Shawn church and made 385whp on his dyna pack. I ran the car today at Raceline in Temple City,CA with their dynojet and the car only dynode at 326whp. That's a whooping 60hp less!.
My car has been boosted for over 15,000miles. I have 0 problems with the car or the tune. My wide band shows about 14-15 on idel and low 11"s when in boost. But at the dynojet at race line, their wideband is showing 13.5 almost 14 to 1 air fuel in boost. Is this even possible? If that was true should the engine just blow up?
386whp at churches
326whp at raceline
pic of the engine bay
Old 11-15-2012, 05:09 AM
kbouchard1092's Avatar
Default Re: churches dyna pack vs raceline dyno jet. My results 60 less hp on the dyno jet
Your Tq is considerably lower as well. That would explain the 500whp on a 50 trim at 17psi. 440 sounds more realistic
ls joker's Avatar
why so choppy. looks like it needs smoothing
Old 11-15-2012, 11:15 AM
Moderator
TheShodan's Avatar
Different Dynos, give different readings.. We have dynojets, mustang dynos, and dynapacks configured to read like Mustang dynos.
You're fine. Don't stress. Its all just about the math that's used to calculate HP in the end. You should try not to get hung up on such trivial things.
Old 11-15-2012, 12:00 PM
It's wU to the sOLdiEr!
justYncredible's Avatar
That's exactly what my tuner told me
Old 11-15-2012, 12:11 PM
Tony the Tiger's Avatar
It's been too long in between your runs... Something in your car has changed over time, because of how your air/fuel ratio has changed as well. Minor exhaust leak? Old plugs? That will also make the AFR read leaner, but not inside the actual engine.
Maybe you should actually double check everything and making sure the car runs well in general. I see cars recovering lots of power from a good tune-up.
Old 11-15-2012, 12:29 PM
Keyboard Humorist
4drEF's Avatar
Don't touch anything and take it back to church's and make sure your numbers are the same as when he tuned it.
Then you will know for certain if it's your car or the dyno.
Old 11-15-2012, 07:13 PM
Moderator
TheShodan's Avatar
hmm. good point. My first response was based upon the notion that I'm just sick of all these freakin' dick measuring contests under the guise of dyno comparisons
Old 11-16-2012, 01:50 PM
JakeSpec's Avatar
x2
Valve adjustment as well
I tuned my car at church then hit prostreet the next day the loss was 18hp. this was back in 05
Old 11-16-2012, 02:02 PM
gs1gsr's Avatar
Church Automotive Testing is hands down the best shop in SO Cal. Been taking my car there from day one. Shawn/Daniel & Todd are all good guy. Shawn tunes his cars like they are his own. When I leave there i dont even think about taking it else where just to double check. If you dont have faith in your tuner then stay home.
Old 11-16-2012, 03:39 PM
Track Advocate
BLU CIVIC's Avatar
good for you but not helpful at all
i concur with 4drEF and Tony the Tiger. do a tune-up and take it back the original dyno to see if the numbers are close to the same
Old 11-18-2012, 08:24 AM
gs1gsr's Avatar
What ever floats your boat I guess
skata89
03-18-2007 08:07 AM
turboHX
08-23-2004 06:02 AM
The Keeper
05-11-2004 02:43 PM
xstalkrx
03-18-2003 01:55 PM
Quick Reply: churches dyna pack vs raceline dyno jet. My results 60 less hp on the dyno jet
