chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
HELLO,GOOD MORNIN'
Re: chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu? (
swaping out an ecu should kill the memory, but if not just undo the battery.
Unplugging the ecu is all that needs to be done to clear it. I have changed chips at the track with only shutting the car off and the launch rpm would change but I believe blake had observed that the fuel may not instantly be changed even in open loop unless the ecu is cleared.
I was concerned about maybe blowing a fuse or something if thebatery was connected.
bigslimdog
03-30-2004 03:07 PM
