Catch can setup...Is this right? (pic) - Honda-Tech
Old 11-15-2011, 07:17 PM   #1
dE.fUsEd's Avatar
Default Catch can setup...Is this right? (pic)
I have 2 catch cans, the valve cover holes go in to the catch cans, and the catch cans drain back to the block plugs.
Is that right?
dE.fUsEd is offline   Reply With Quote
Old 11-15-2011, 07:24 PM   #2
Default Re: Catch can setup...Is this right? (pic)
i'm not a fan of draining back to block because of the condensation that occurs within the can..some people are into it though.
Freshdot is offline   Reply With Quote
Old 11-15-2011, 07:28 PM   #3
dE.fUsEd's Avatar
I just have straight lines running to and from, the can is baffled and filtered.
Do I need any sort of check valves or anything?
Also, I wasn't sure what to do with my smog canister, but we have emissions here so I just ran the hose to the intake manifold. That ok?
Old 11-15-2011, 08:02 PM   #4
DelSolMarine's Avatar
That setup is good...
I have had drain back on my car for over 3 years and daily drive it... Tony Palo has drain backs on his 1000+ whp integra running 8's and hasnt had problems... I think the pros clearly outweigh the cons.
DelSolMarine is offline   Reply With Quote
Old 11-16-2011, 07:15 AM   #5
dE.fUsEd's Avatar
Thanks! This will be my first turbo build. Actually bought the motor from someone here.
Hoping it is what I was told it is.
Old 11-16-2011, 07:40 AM   #6
ever drain a filtered catch can? it's not pretty and I wouldn't want that going back into my engine, i'd rather keep adding oil when it gets alittle low.
side note: i'm pretty sure tony palo is changing his oil after every track day.
Old 11-16-2011, 12:45 PM   #7
mechanix619's Avatar
Having a drain back on a race car is drastically different than having one on a daily driver. When racing the oil gets changed after after every event, possibly even between runs.
Depending on how I drive the car my blow-by ranges from decent-to-nasty. I definitely don't want the nasty stuff back into the engine.
mechanix619 is offline   Reply With Quote
Old 11-16-2011, 03:47 PM   #8
right and are you sure he runs a drain back and not a slash cut to the exhaust?
something about letting milkshake back into my motor doesn't sit right with me.
you are better off using those plugs on the back of the block to relieve more pressure as there is way more crankcase pressure in well, the crankcase.
Old 11-16-2011, 06:20 PM   #9
Just Another Mod on H-T
EsotericImage's Avatar
EsotericImage is offline   Reply With Quote
Old 11-17-2011, 02:18 AM   #10
m3tech95's Avatar
x2^
m3tech95 is offline   Reply With Quote
Old 11-17-2011, 11:40 AM   #11
ekcoupeh22's Avatar
why are you running 2 catch cans? if its a mild build you dont need 4 lines coming off the valve cover just 2 and 2 off the block ditch the whole drain back thing. imho its stupid. i would spend the money and get a T1 catch can and call it a day!
ekcoupeh22 is offline   Reply With Quote
Old 11-17-2011, 02:13 PM   #12
dE.fUsEd's Avatar
Quote:
It's a benson sleeved gsr block, pauter rods, cp 9.1 pistons, fully ported b16 head, skunk2 stage 1 cams, blah blah.
Plan to be around 500hp with a gt35r. Motor made 690 on race fuel with the previous owner.
Old 11-17-2011, 02:32 PM   #13
ekcoupeh22's Avatar
Yeah ok it's not a mild build lol I would just do a T1 catch can with the 4 on the valve cover and the 2 to the block and be done! Same setup I just picked up!
Old 11-17-2011, 03:11 PM   #14
dE.fUsEd's Avatar
Really didn't feel like relocating my battery.
I have drain valves for these cans. I may just use them for awhile and see what kind of blow-by I get. Would probably end up having to get another catch can though for the block or just T'ing my valve cover lines.. lol
Appreciate all the info!
Old 11-17-2011, 03:13 PM   #15
dE.fUsEd's Avatar
I will post a pic tonight. Car goes to in to get the motor tested and a quick N/A tune tomorrow. Have to wait a couple weeks for the rest of the turbo setup.
ebay catch cans rdeezy78 Forced Induction 13 09-12-2006 05:47 AM
catch can on a H BaNAnABoAt689 All Motor / Naturally Aspirated 6 06-24-2005 12:53 PM
nerdsports DIY catch can... 976 Honda Civic / Del Sol (1992 - 2000) 26 03-12-2003 06:45 PM
Oil Catch Can - Theoretical Vacuum Issues IN VTEC Tech / Misc 3 11-01-2002 06:27 AM
WOW, I am impressed by the moroso oil catch can citanest Acura Integra Type-R 23 03-25-2002 07:11 PM
Tags
97, back, block, catch, civic, drain, draining, forced, good, honda, hondatech, induction, oil, set, setup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
