Wastegate not centered on manifold? does it matter
I seen various log manifolds all I want to know is if there is any issues if it mounts to the cylinder 1-2 exhaust ports instead of being centered in the middle.ill get pics if needed most of what i see is centered
Re: Wastegate not centered on manifold? does it matter
k well that worries me a lot, even using a tial wastegate or anything for that matter to correct the problem? I dont want to step on it and find out there needs to be confidence its going to work properly. heres a pic, its off to the side like im saying
similar cars set up
similar cars set up
Even the best wastegates can only control the amount of exhaust that they see. Those log manifolds force the wastegate to only gate the exhaust out of a single runner and allowing the other three runners to run free. Not to mention the exhaust has to make a hard 90 to get in the wastegate.
Those cast log manifolds literally rely solely on heavy backpressure to allow the wastegate to regulate exhaust pressure correctly.
I didnt really understand them, looking at it thats pretty hektic. so excess boost air is going to be dumped right into my down pipe but has that crazy 90bend. I could try it I guess and watch for boost creep
Also the exhaust will have lots of back pressure its a 2.5" straight with jdm gsr axleback but might go with a stealth instead. dp is 3" modding to 2.5" pipes
yes second pic is home made but similar.
