Car runs soo hot
Car runs soo hot
bad rad
http://www.flickr.com/photos/62032926@N07/6518922117/http://www.flickr.com/photos/62032926@N07/6518921965/
Re: Car runs soo hot
I'll let you figure it out, but i'll give you a hint..
Car stops = idling slow = low rpms = not over heating
Car moves = rpms up = water pump suppose to be moving water = car still runs hot??
If you replaced your thermostat and dont have any leaks or air bubbles in your system, i suggest looking the next place that deals with cooling which is...?
Thermostats are designed to stay wide open when they go bad (not to say they always do)
If you had to put water in it.....but have no leaks......I say you bleed the coolant system. You might have air in the system.
Not coolant itself....all it does is stop the water from freezing.
Water pump......You can take the dust covers off and look for leaks.....if it was seized up.....water would not circulate and get hot easy.
Does it cool off when you drive it? (aka get the wind pushing on the rad nice and hard)
no, it stays normal when the car is idling and not moving. when i start driving and the turbo is spooling and/or building boost the car gets hot. the pic is me driving 65 mph on the fwy
JEEEZUS KRIST!!!!
dont let that **** climb dude! c'mon not to bag but if your letting your temp get that high. you should take it to someone who understands vehcles better.
Make sure fans are coming on
Change thermostat
Top off fluid
Open radiator cap once car is on and look inside the radiator you SHOULD see water moving from left to right,
if not it could be your pump.
And make your you bleed the system when the vehicle is on a slant, with nose up.
Change thermostat
Top off fluid
I think its all been said!
Make sure you bleed the air out of the system : run it with the radiator cap off untill it get to operating temp, then top off the radiator & put the cap on, I would do that first because it's the cheapest. While your doing that after you put the cap on let it idle and watch to see if the fan kicks on!
If that doesnt fix it check the water pump, I would look for leakage, as well as remove the timing belt and check the pulley for play, but if you are doing all that you might as well replace it considering how much time you will have in it to check the pump.
If you are using S300, you can lower the temp that the fan kicks on!
JEEEZUS KRIST!!!!
Change thermostat
Top off fluid
Change thermostat
Top off fluid
trust me man i was trippin too when i saw it, but i had my buddy on the phone with me while it was happening and he said it was ok. he builds motors and practically put my car together he knows his stuff for sure.
just talked to my buddy that had the motor before me, changed the TB and Water Pump a couple months before i got it so they are basically new, fan does come on and i did have it full with coolant with the cap off. so yeah tomorrow im going to try a new thermostat and go from there, thank you for all the input
You need to find a new buddy. If he thinks that is ok for driving, I wouldn't trust what he says. What engine management are you running? Can you log the car while you are driving to see the real temp? Was the car tuned? What fan is on the car? What radiator?
had an issue with my car doing this last year. It is very possible you have a pin size hole in the radiator somewhere and you dont even see it. Its enough for the radiator to leak and you not even notice it. If you have a spare radiator laying around, give it a try. what do you have to lose.
i always stick a funnel tight into the radiator this way the coolant rises up the funnel as the car runs this also makes it the highest point in the cooling system. I get all the air out everytime. Let it run until the thermostat opens ( bottom hose gets hot) then squeeze both hoses to push whatever air is trapped in it....i usually jack the front of the car up slightly as well.
ALso cheap *** radiator doesnt sound like a good idea in a turbo set-up. How big is you're FMIC? sometimes that can also block airflow to the radiator, what fan are u using? is it coming on when the gauge start climbing at that point it should def be on
Those Temps are wayyyy to hot. You need a real temp gauge but i am certain that is way to hot to be driving. FActory gauges suck... I use my Hondata to see a digital readout and from 180-210 the gauge does not move till after 210ish. You are in the 230 range maybe higher at that point. That is wayyyy to hot. YOu are going to run into more serious problems driving it that high
Sounds like your not bleeding it correctly or you have a leak if you start driving it and then have to add more coolant. Once you get that figured out I bet your going to have a problem getting airflow through that radiator at higher speeds.
i think this is my new favorite forum, wow so many responses thanks. Im gonna try and answer all questions asked forgive me if I miss some.....
I have an electric slim fan dont know what brand, and my rad is a no name half size, I dont have room for 2 fans, the car is tuned and i have an s300, when i turn the heater on it does get hot, here is a pic of the intercooler so you can see the size of it, im going to work on it now, new thermostat, dont have a bleeder gonna try the slant fill and squeeze air out(if it gets hot after i will get a bleeder) also need to replace the axle, put on my turbo filter and put on my suspension finally, might be awhile
http://www.flickr.com/photos/62032926@N07/6310832974/
you dont need to squeeze the damn hoses broo... you might be pushing air in instead of fixing your issue.
Idk but in my car i have the slim fan the way you have it BUT infront of the radiator. it sucks sooo much hot air out Plus your not gonna be blowing that hot air back under the hood! give it a try if nothing else works.
