Car ran fine, all the sudden it runs like crap and won't idle
Old 04-27-2009, 06:02 AM
No Sales Forums
Trojan Man's Avatar
Location: Reading the Chronicles and Blowin Trees in Virginia
Default Car ran fine, all the sudden it runs like crap and won't idle
So I just finished up my car, got it running and it was just fine. Ran PERFECT for 2 days.
I went to just start it up yesterday and it didn't want to turn over. I thought I may have touched my conversion harness so I checked that and made sure all the wires were straight and in their place. The car starts and runs but it smokes like no other and won't idle unless it has gas and when you hold the gas it sounds like complete **** (not like it did for the 2 days prior)
My first initial problem was the fuel pump. It was replaced and works just fine now and I can still hear it prime. I know this is kinda hard to figure out over the web so I'll try to get a video today. The car scares me when I have to rev it to keep it going because it sounds so bad and smokes moderately (its not A LOT but its a decent amount).
The car won't idle and will die and it won't start unless I play with the throttle.
I'm going to pull the plugs today and check them as soon as I can find my spark plug socket.
Any advice? Thanks H-T.
Old 04-27-2009, 07:54 AM
93turbo16's Avatar
Default Re: Car ran fine, all the sudden it runs like crap and won't idle
We need a lot more info on the setup to help you out man.
Does it have a different map sensor.. if so check the vac line going to it if it has one.
What injectors, EMS, etc would be a good place to start.
Old 04-27-2009, 08:21 AM
No Sales Forums
Trojan Man's Avatar
Stock map sensor.
Stock injectors just for getting it running, walbro 255 just installed and working perfect, and stock P28 on a Boomslang OBD2 to OBD1 conversion harness.
Old 04-27-2009, 10:31 AM
blaze the chemi's Avatar
Make sure you didn't skip a tooth or so on your timing belt. Is your VC cut at all? Also...you have converted your injector plugs to OBD1 or are you still using your OBD2 injector system?
Old 04-27-2009, 10:55 AM
No Sales Forums
Trojan Man's Avatar
OBD2 injectors. They are stock Si injectors.
VC and all the longblock is stock.
Old 04-27-2009, 12:50 PM
wunfstgsr's Avatar
I believe it lies between a few things youve done, for one you need to convert you injector clips to obd1 clips so the ecu can properly run the injectors using the obd1 conversion, second i believe your fuel pump is not able to work properly because your ecu has a base map for a stock fuel pump and cannot properly work untill your fuel map is tunned for the pump this is why i installed my fuel pump and injectors when i got to the tunner. or your running with a cylinder missfire or multiple this can be caused by a bad injector or you have a bad connection to one or more of your injector clip wires, also bad dist wires or coil will cause poor idle and drivability, what was done before and between the 2 days it was driving fine?
Old 04-27-2009, 02:04 PM
Ls_dx's Avatar
CEL? vac leak? plugs and wires??
Old 04-27-2009, 02:14 PM
E85B18's Avatar
Did you push the car without a tune? When my car started to idle like **** I did a quick compression test. 90 is 2 cylinders is no good. My rings were gone
Old 04-27-2009, 02:35 PM
EKlscoupe_98's Avatar
did you gap your plugs??????
Old 04-27-2009, 03:33 PM
Sr420Det's Avatar
Check your main relay, but it shouldnt be smoking like that. Do a compression test and report back.
Old 04-27-2009, 04:08 PM
No Sales Forums
Trojan Man's Avatar
I got the car to fire properly today. Please close thread. Thanks.
Old 04-27-2009, 05:28 PM
MiraiZ's Avatar
I was going to ask this too. It might be that you're running really rich. Check your plugs to see that they aren't fouled or wet from gasoline.
No Sales Forums
Trojan Man's Avatar
They were all gapped to 50 or 52... whatever the stock honda was.
I will change them to 28-30 when I get tuned.
Old 04-27-2009, 05:52 PM
95civhb's Avatar
what did you do?? just out of curiosity?
Old 04-27-2009, 05:54 PM
No Sales Forums
Trojan Man's Avatar
My car is weird... i randomly wouldn't start after running fine for 2 days and today it randomly started after not running yesterday. I didn't do a single thing.
Old 04-27-2009, 07:25 PM
K i l l a B e e.'s Avatar
well that means there still is a problem. sounds like electrical to me. you should get to the bottom of it because it will come up again later on.
Old 04-27-2009, 07:29 PM
No Sales Forums
Trojan Man's Avatar
I think it could of been the ECU conversion harness. I tinkered with it some more. Either that or my power source since my battery was weak as hell and we were using a not so great bettery to get power from also... This time we jumped it from a perfectly fine daily driven ford ranger. She cranked right over.
Old 04-27-2009, 07:45 PM
well it doesnt matter about the battery once the car is turned on. The alternator will do the rest.
Old 04-28-2009, 06:19 AM
Sr420Det's Avatar
Not if the battery wont charge at all. I would still pop the cap off the main relay, my car would do that sometimes (wouldnt smoke though) and turns out the relay was all fkd up.
Old 04-28-2009, 06:51 AM
No Sales Forums
Trojan Man's Avatar
Well the relay was changed out with another used relay because thats what I thought the problem was at first when it wouldn't even turn over.
Old 04-28-2009, 10:36 AM
New User
HondaKylehasnolife's Avatar
Tune it on **** plugs then just buy new ones after the tune! best idea ever!
Old 04-28-2009, 10:50 AM
what does that have to do with fixing his problem?
Old 04-28-2009, 10:51 AM
i dont understand how his car would smoke if the battery doesnt work. (unless the smoke is coming off the battery itself)
Old 04-28-2009, 11:14 AM
No Sales Forums
Trojan Man's Avatar
He's being a smartass and has nothing to do with the situation at hand.
I don't either because the car ran fine before and then that 1 day it acted up. I know this sounds bad of me, but unless it keeps doing it... I'm not going to worry about it for now.
Old 04-28-2009, 02:25 PM
champLSinteg's Avatar
Well you dont want this to happen when you're on the dyno and ruin your day!
Quick Reply: Car ran fine, all the sudden it runs like crap and won't idle
