Car Bogs/Jerks Randomly at partial throttle: p28 + Hondata... TPS issue?
Old 10-23-2005, 05:24 PM
turbotime's Avatar
Default Car Bogs/Jerks Randomly at partial throttle: p28 + Hondata... TPS issue?
Hey my car behaves very strangely sometimes completely randomly. At like 5% throttle it will seem to bog and jerk. This only happens SOMETIMES tho- nothing in particular causes it, and it will only bog and jerk at light partial throttle. Also when going from >5% throttle to 0 throttle is will kind buck, not smoothly transition.
It only happens sometimes, and it happened ths whole time the car is running. So if i start it and its doing it- it will keep doing it til i shut it off. But if i turn it on and its fine, it will be fine until i shut it off again.
No CELs, Dyno Tuned.. think its a hondata bug? Dying TPS Sensor Maybe? Poor Partial throttle tuning?
Thanks for any insight...
Old 10-23-2005, 07:55 PM
ccivic's Avatar
Default Re: Car Bogs/Jerks Randomly at partial throttle: p28 + Hondata... TPS issue? (turbotime)
My car did the same when my IACV was f'ing up. Fixed it (wiring.. shorted ECUs) and the problem is gone.
Old 10-23-2005, 08:04 PM
Banned
turboteener's Avatar
I have been having a similar issue with Hondata. Mine will buck slightly at partial throttle. Say coasting up to a stop and rolling back onto the throttle it will not transition smoothly. It will also cut out and buck pretty hard at WOT. When I shift it feels like there is a delay when the injectors cut back on. I am still trying to tune it out.
Check out this link.
http://www.hondata.net/forum/v...e56f7
No help there either.
Old 10-23-2005, 08:06 PM
turbotime's Avatar
yeah i am good at WOT but patial sucks, but only sometimes. Its weird how it isnt consistent.
How do you check the IACV? How do you short it/bypass it?
Old 10-23-2005, 08:12 PM
Moderator in Chief
Muckman's Avatar
Default Re: (turbotime)
Does it do this at low speeds in low gears or at any speed?
Old 10-23-2005, 08:19 PM
turbotime's Avatar
any speed any gear- the throttle just has to be really partial like 5% ish. Also there isnt a smooth transition from partial throttle to closed throttle.
Its weird cause its so inconsistent, some starts itll be smooth and transistion fine others it wont....
Old 10-23-2005, 08:22 PM
turbotime's Avatar
im wondering if its iacv related becuase my idle is very high too... between 1000 and 1500
Old 10-24-2005, 05:38 AM
turbotime's Avatar
bump
Old 10-24-2005, 08:08 AM
boosted k20's Avatar
do u have a GM 3bar map sensor? that might be the problem. also i know in uberdata, theres usually a fuel cut when u r at high vacuum, but there has been a fix for that. im not sure about how hondata fixed that problem
Old 10-24-2005, 09:11 AM
turbotime's Avatar
no im pretty sure i am using the stock map sensor... idle is bouncing for some reason... im not sure if its the IACV or a vacuum leak. Vacuum is pretty solid at 22". Could IACV cause a bouncing idle?
chewyv
Engine Management and Tuning
04-17-2017 07:19 PM
allmotorpackage
17
04-12-2011 10:45 AM
Aeka GSR
04-28-2004 09:26 AM
integracivic94
02-02-2004 01:50 PM
StinkyTofu
04-17-2003 05:50 AM
Quick Reply: Car Bogs/Jerks Randomly at partial throttle: p28 + Hondata... TPS issue?
