can you use a straight feed fitting instead of banjo bolt on t25?
Old 03-12-2003, 09:42 AM
ZCHF2's Avatar
Default can you use a straight feed fitting instead of banjo bolt on t25?
the setup that i got uses a straight fitting that goes right into where the banjo bolt would be. I was wondering if this would work, becasue i'm not sure how the banjo works. Does the banjo bolt press something down to open the line? thanks
Old 03-12-2003, 09:46 AM
turbod16y8's Avatar
Default Re: can you use a straight feed fitting instead of banjo bolt on t25? (ZCHF2)
yea that would be ok. i did it on mine to run the water lines. on the oil u should go with stainless steel lines. i have a oil fitting that will fit the oil. its a 7/16 to a -3an for sale
Old 03-12-2003, 11:24 AM
ZCHF2's Avatar
Default Re: can you use a straight feed fitting instead of banjo bolt on t25? (turbod16y8)
do you know where to get the oil return flange that bolts to the t25? I can get everythying other thatn the actual flange that bolts up to the turbo. know anything that will help? thanks
brian
Old 03-12-2003, 11:35 AM
UberTeg's Avatar
Damn it, I wish you kenw u had that last week Are you purposly hiding the stuff I need from you?
Old 03-12-2003, 12:52 PM
civictypenos's Avatar
brian
try a junk yard,got mine from there,or you can get it @ http://www.roadraceengineering.com/intercoolers.htm for $13
Records
10-12-2012 01:43 PM
ericstambaugh07
04-30-2007 04:08 AM
skiwithcars
06-27-2006 08:07 PM
adseguy
09-26-2004 06:46 PM
SiR Kid
04-15-2003 04:30 PM
Quick Reply: can you use a straight feed fitting instead of banjo bolt on t25?
