Can you turbo a honda civic motor? - Cobra owner asking.
#26
Re: Can you turbo a honda civic motor? - Cobra owner asking.
id say since you want to just play around. go get a b18b and an ebay turbo kit. get it all tuned and your good for a play beater. now if you are gonna do it right your 2-3k budget isnt gonna cut it.
#27
My point is he should buy the right parts now instead of upgrading later. Like t1 said set a goal you want and go after it instead of upgrading and spending twice. Get a nice turbo kit that will insure him for the future if he ever want more hp.
Get a nice turbo kit now and in the future if you do decide more power, all you will need is a built engine and more boost
#29
ehhh not so true stock blocks are very very under estimated, and in the hands of a great tuner (this is where the money should be spent) a stock motor can get it done as well
#30
This is one case where I choose cheap and fast I'm not to concerned with reliable or 500+ hp from this project. My Cobra already fits that bill and cost me a ton of money.
I'm just looking for another side project to play with and have fun. A turbo 4 cylinder really fits that bill and sounds fun as hell.
As for HP goals. What ever I can make on a stock internals motor will be fine. I just want to turbo it and have some fun.
To the fellow who posted those shops in KC, thanks man. I'll give them a call and see if I can get some info.
Anymore info on turbo'ing 00-05 model years would be great. Those model years seem to be the most commonly available for sale and easiest to get my hands on.
#31
Lol if those are your choice I say a b18b engine and a eBay turbo kit with 25psi of boost and run 11s
#32
Since you said you would still like to aim for the newer civics because you like the way they look and they're a little newer, thats fine if thats the route you want to take. Just keep in mind that the only motor you can swap into a 01-05 civic is a k series otherwise you're stuck with the D17. The K series swap isnt exactly cheap and boosting the D17 is going to be more expensive and a little bit more difficult than boosting the earlier generation cars/motors. just fyi
In all honesty though, you're REALLY going to be better off with the earlier models (88-00)
#33
to be more specific the cars you want to look for:
88-00 civics
90-01 integras
if you like preludes and accords:
92-01 preludes
90-97 accords - i'm not as familiar with the potential of 98+ accords, but they may be just as easy to modify and tune as the earlier models. For that info you'll have to research.
88-00 civics
90-01 integras
92-01 preludes
#34
Alright guys. You've convinced me 88-00 is the way to go. I will search those model years. I will probably get as close to 00 as I can so I can get good condition and lesser miles... if possible but any good deal will be fair game.
#35
^^great now for engine management. Of course you can go with whatever you like. There are a lot of options. A relatively inexpesive and very effective option (which is the option I like) is a "chipped & socketed OBD1 ecu" I would recommend you research this. Depending on what car you buy you may need a conversion harness ($75) Basically its a modified factory honda ecu that allows your tuner to burn several choices of software onto it.
#37
most civics with exception to the 99-00 civic si all come with a D series motor (sohc 102-127hp) The Si's came with B16A2 (DOHC 160hp)
The integras ALL came with B series motors (DOHC) depending on which model you either get RS,LS came with B18A1 and B18B1 both around 140hp The GSR B18C1 makes 170 hp I think ,and the Type R B18C5 makes 195hp
#38
https://honda-tech.com/forums/forced-induction-16/official-turbo-lsvtec-thead-post-your-setups-1509557/
https://honda-tech.com/forums/forced-induction-16/post-your-turbo-gsr-hp-numbers-1501150/
https://honda-tech.com/forums/forced-induction-16/sohc-boosted-set-ups-chime-place-single-slams-1643764/
Hondata.com
Phearable.net
Go-Autoworks.com
JHPUSA.com
is all you need.....
Hondata.com
Phearable.net
Go-Autoworks.com
JHPUSA.com
#39
1 Post
^^^ those are good companies but he is trying to stay within 2-3g.
S300 with boost option is around 650 which you can run neptune rtp and it's cheaper '450' and offers the same capabilities and more. You could run crom free which would be no charge except the price of socketing/chipping your ecu '100' but doesn't have all the bells and whistles but would be fine for what you're doing.
#40
http://kansascity.craigslist.org/cto/2256721167.html
So to get the DOHC motor I need to find an integra? Or a 99/00 SI model civic?
#44
I was going to go look at this car tomorrow but you're saying it's the SOHC version that I don't want right?
i think a del sol would also make a fun little car. it has a removable top too. only downside is that its a 2 seater.
#45
So are the SOHC 92-00 motors considered b series motors? I'm a little confused on that.
#47
no they are d series. stock motor sohc engines can handle about 200WHP safely. on a built motor tho its a whole different ball game tho. but people have made as much as 400WHP on a stock sohc.
b series is dual cam.
#48
There are some civics you may find on craigs list and the classifieds that already have a B series swap done, but you may not know right away how well its been taken care of until you start getting into it. The ones that Ive seen look pretty molested and ragged out, but who knows you may get lucky and find a clean one in nice shape.
If you want the B series (DOHC) already in the car from the factory then yes you are correct you need to find an integra or find a 99-00 civic si. I think the guys with the B18 A/B's (non-vtec) boosted on stock bottom ends are making around 250-275whp if I'm not mistaken. Someone correct me if I'm wrong.
#49
if you are on a budget the best thing to do is buy a b series swapped civic/crx or del sol. you can boost a b series motor and it will be a fun lil car on 10lbs. on psi i was pulling on c6 vets.
#50
Moderator
No. the SOHC motors follow the same years as the DOHC engines. The SOHC guys get a bad rap because it takes much more in the way of engine work, parts, and tuning to do what the B-series (DOHC) versions can do with less money.
B-series engines are DOHC
D-series engines are SOHC
K-series Engines are DOHC
H-series engines are DOHC
Check also on wikipedia under "civic" to see the different engine models. for what you're trying to do, B-series are best to use. Those engines can be swapped into other civics even though they came from integras. (this is also why they are highly stolen)
