Difference between stage 3 and 5 comp. wheel?
Old 09-02-2005, 12:41 PM
DelSolMike's Avatar
Default Difference between stage 3 and 5 comp. wheel?
Im looking at a T3/T61 turbo and I was wondering what is the difference between the stage 3 and stage 5 wheel. Any help? Thanks!
Old 09-02-2005, 12:44 PM
b18bturbo's Avatar
Default Re: Difference between stage 3 and 5 comp. wheel? (DelSolMike)
stg 3 and stg 5 is talking about the exhaust wheel its no the compressor wheels.
stg 5 is larger wheels 2.795" inducer compared ot the std stg3 wheel which is 2.559" inducer
stg 5 will hold more power vs stg3 and flow more
Old 09-02-2005, 01:09 PM
PM-Performance's Avatar
Default Re: Difference between stage 3 and 5 comp. wheel? (b18bturbo)
how does that go in trims though.
I never understood the stages.
You got P trim, Q Trim, O trim, etc .
Is a P trim a stage 5 and O trim maybe stage 3?
too many damn options these days
Old 09-02-2005, 01:15 PM
Maveric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">how does that go in trims though.
too many damn options these days</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">how does that go in trims though.
Pretty much what he said....Stage 5 or 3...... turbine wheel will effect when the turbo begins to make boost but more importantly how much more power the turbo can make.3 is obviously smaller than 5
stage 3 is standard on all newer garett turbochargers...stage 5 is usually good for about 30whp more, also more lag
o,p,q,gt,gtq....are T-4 terms
T3 turbochargers do come with the option of a p-trim which basically makes it react like a T4 o trim..
Hope i helped.
Old 09-02-2005, 01:21 PM
BlueShadow's Avatar
Default Re: Difference between stage 3 and 5 comp. wheel? (Maveric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maveric &raquo;</TD></TR><TR><TD CLASS="quote">Pretty much what he said....Stage 5 or 3...... turbine wheel will effect when the turbo begins to make boost but more importantly how much more power the turbo can make.3 is obviously smaller than 5
stage 3 is standard on all newer garett turbochargers...stage 5 is usually good for about 30whp more, also more lag</TD></TR></TABLE>
Can you guys give an example of how the boost pattern might look? or how much power? Or is it just the larger wheel will make more power but it will have slightly more lag? Also does the stg wheel have anything to do at all with the turbine outlet size? can either stg wheel be had with either 2.5" or 3" outlet sizes?
TIA
Old 09-02-2005, 01:26 PM
Civicman86's Avatar
Ok so your saying an extra 30hp as an average. How much is the average loss on spool time?
Old 09-02-2005, 05:17 PM
Maveric's Avatar
Default Re: (Civicman86)
about 500-800 rpm's....even bigger gap between STG5 and Ptrim....
is this car daily driven???
What kind of budget are you on??
Answer these questions, it will help you better understand what you need.
Also for a street driven honda i like stage 3, more responsive/usable....unless your looking to max the potential of your turbo i would just go stg3
Old 09-02-2005, 05:25 PM
blown_LS's Avatar
Default Re: (Maveric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maveric &raquo;</TD></TR><TR><TD CLASS="quote">about 500-800 rpm's....even bigger gap between STG5 and Ptrim....
Also for a street driven honda i like stage 3, more responsive/usable....unless your looking to max the potential of your turbo i would just go stg3</TD></TR></TABLE>
Well put i curentlly run stg 5 on my dsm and it is a ton better on top end then stg3 wheel but the diff is about 500rpm's spool.
Old 09-03-2005, 08:48 AM
M.A.R.C.'s Avatar
Default Re: (blown_LS)
stage 5 vs stage 3 physical diff:
TurboJesse
06-09-2006 07:26 AM
98h22
03-13-2006 12:02 PM
KingDsi
07-31-2004 07:49 AM
Nextelbuddy
06-26-2004 05:38 AM
*Boostwerks*
12-21-2002 07:10 AM
Quick Reply: Difference between stage 3 and 5 comp. wheel?
