Can i use thicker oil for a blown turbo
Old 04-30-2002, 06:32 PM
Ri5e's Avatar
Default Can i use thicker oil for a blown turbo
the turbo smokes slightly. If I use thicker oil, say 20w-50 or something, will it still smoke?
Old 04-30-2002, 06:51 PM
Bin
Bin's Avatar
Default Re: Can i use thicker oil for a blown turbo (BG Boost)
Get your hands on some Lucas Oil that should stop the smoking.
http://www.lucasoil.com
Old 04-30-2002, 06:56 PM
Ri5e's Avatar
Default Re: Can i use thicker oil for a blown turbo (Bin)
really ... hmm... did you have slightly messed up oil seals and use this and it worked or something?
Old 04-30-2002, 07:06 PM
Bin
Bin's Avatar
No personal experience.
I have 2 friends that had minor smoking due to blown oil seals. They used Lucas Oil and the smoking stopped. It's a temporary fix until the turbo has been repaired. Doesn't really last though. 1 of the guys is having the turbo repaired now because even with the Lucas it still smokes a lot.
If you're smoking a lot the Lucas might not help at all.
Perhaps some other H-T members have used Lucas Oil as well?
Sorry I can't be anymore help than that.
Old 05-01-2002, 05:08 AM
PrecisionH23a's Avatar
why put lipstick on a donkey. i recommend sending the turbo off to be fixed, im sorry to hear about your luck. ill see if i can contact a friend of mine at turbonetics and see what i can do for you.
kxrider25
02-24-2011 09:59 AM
CRXdan
04-04-2005 06:28 PM
71 mgb
11-12-2003 10:49 AM
T3T495GSR
12-12-2002 10:44 AM
Kamin
03-03-2002 12:17 PM
Quick Reply: Can i use thicker oil for a blown turbo
