Can I still use this block? (4g63) Deck dent.
Old 12-09-2007, 10:01 PM
MidShipCivic's Avatar
Default Can I still use this block? (4g63) Deck dent.
This block suffered a collision and and valve dug into the deck and I wanna use this block for a build and it appears that the head gasket doesn't touch this area at all ( although when squished it might) so I'm not sure what I'm gonna tell the the shop I'm sending it out to.
I can't get the the picture to come out clearer for some reason.
<FONT COLOR="red">hi resolution version </FONT>
http://img.photobucket.com/alb...6.jpg
Old 12-09-2007, 10:04 PM
Man U FTW
Schister66's Avatar
that block looks nasty as hell...as for the dent, you should talk to a machine shop and see what they can do for you...
Old 12-09-2007, 10:12 PM
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">that block looks nasty as hell...as for the dent, you should talk to a machine shop and see what they can do for you...</TD></TR></TABLE>
Yeah I know it looks nasty there's a lot worst but that can easily be changed with a hot tank bore/hone but the dent is what I'm talking about.
Old 12-09-2007, 10:15 PM
Man U FTW
Schister66's Avatar
i'd imagine that most machine shops have seen worse blocks come through the door...the only way you're going to know is by taking it somewhere and letting them assess the damage. I really dont see why it wouldnt be fixable...it doesn't look that terrible from the pictures
Old 12-09-2007, 10:21 PM
Oh and just to answer the question before anyone says those are cracks it's actually debris not cylinder wall cracks.
Old 12-10-2007, 05:56 AM
Finest's Avatar
Default Re: (MidShipCivic)
I wonder if you can't just o-ring the block to help seal it further?
Old 12-10-2007, 06:30 AM
agrn93ls's Avatar
Default Re: (Finest)
i wouldn't be concerned about using it if it were me. smooth it out a lil and should be fine. that is a very very small area of the sealing surface if any at all. and hell you might be able to add a little metal there bore it and deck it and never even know it was there.
Old 12-10-2007, 09:52 AM
HiProfile's Avatar
Default Re: Can I still use this block? (4g63) Deck dent. (MidShipCivic)
I don't see why it would be an issue. Just make sure its decked and honed, and it will be all of 0.25cc larger in chamber size than the others. Chances are the crappy ems DSM's use will fill that with carbon in notime.
Old 12-10-2007, 10:45 AM
CerealKiller's Avatar
Yeah, block should be able to get re decked. I would suggest getting new sleeves in it. just my .02
Old 12-10-2007, 11:14 AM
Default Re: Can I still use this block? (CerealKiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CerealKiller &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, block should be able to get re decked. I would suggest getting new sleeves in it. just my .02</TD></TR></TABLE>
I've never heard of 4g63's being re sleeved.
Old 12-10-2007, 11:16 AM
93supercoupe's Avatar
Default Re: Can I still use this block? (MidShipCivic)
easy on the noob lol
Old 12-10-2007, 11:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
I've never heard of 4g63's being re sleeved.</TD></TR></TABLE>
Oh ****, my bad.
:takes both hands to head and nods, no:
Old 12-10-2007, 11:56 AM
.RTErnie's Avatar
My instinct would be to say...no go get a new one. Because why skimp out on a very important detail. i'm sure it would work... Im sure it would work well... but "what if".
I'd just rather not take the chance.
hell...maybe after you bore it and deck it...you wont even notice it
Old 12-10-2007, 12:14 PM
I'll see what the machine shop says.
Old 12-10-2007, 12:15 PM
narfdanarf's Avatar
Default Re: Can I still use this block? (.RTErnie)
they've been resleeved before. Although that is highly uncommon due to the hella cheapness of blocks.
Old 12-10-2007, 12:18 PM
agrn93ls's Avatar
you think you could just weld/fill in the area and bore/deck it smooth?
its not contacted by the rings or anything so i would assume it'll be just fine
Old 12-10-2007, 02:12 PM
hybrid_KJ's Avatar
Default Re: (agrn93ls)
I've seen blocks were people have used opened up the upper portion of the sleeve to de-shroud the valves on special applications. I think you are good to go.
Old 12-10-2007, 07:31 PM
The picture makes it look huge. It's where the bore chamfers @ the tip of the bore its about a half mm wide.
Old 12-10-2007, 08:23 PM
b18bEKcoupe's Avatar
Looks fine to me. Head gasket doesn't seal that close and the rings aren't anywhere near it. Looks small anyways. Some engines outside the honda world have a decent bevel along the entire cylinder to help in assembly. I wouldn't worry too much.
Old 01-14-2008, 01:14 PM
Here's this same block if anyone is wondering.
Still has to be resurfaced and hot tanked.
Looked like this before.
Old 01-14-2008, 06:40 PM
Kevin's Avatar
What's up with the projects in your sig? I've seen em there for a while but never any pics of progress.
Old 01-14-2008, 06:52 PM
HiProfile's Avatar
Default Re: (Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevin &raquo;</TD></TR><TR><TD CLASS="quote">What's up with the projects in your sig? I've seen em there for a while but never any pics of progress. </TD></TR></TABLE>
I think because most owners brag about the upcoming AWD launches and $$$ savings, but are embarased when it turns into a money pit.
And/or they have their own forums.
Old 01-14-2008, 07:10 PM
Default Re: (Kevin)
It's just that I'm not ready to post them up yet to be honest. I've done one on my Nissan's engine and none about my Civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
And/or they have their own forums. </TD></TR></TABLE>
I'm not embarrassed at all it takes tons of money to do these things and that just gives openings for people to put you down about it.
I want to use the element of surprise, but at the same time post by post on projects on here are beneficial because it helps me think when people shoot idea's at me to help me better my car, so please do expect a thread on all of these cars.
Old 01-15-2008, 02:40 PM
Kevin's Avatar
That's cool, they are definetly some ambitious projects. Looking forward to seeing a thread about em when they are done.
Old 01-15-2008, 07:39 PM
jdmcoop's Avatar
Default Re: (Kevin)
ERL can re-deck that for you and it looks like it will clean up. You can also go with a 1mm size bigger piston and by doing this it will bore your sleeve out to where the dent will be gone. By doing both of those it should definately take the dent out and we can do it in a couple of days for you.
Quick Reply: Can I still use this block? (4g63) Deck dent.
