WASTEGATE OPENING EARLY....
Old 07-04-2006, 10:45 AM
afrothunda713's Avatar
Default WASTEGATE OPENING EARLY....
I HAVE A 35 MM WASTEGATE TIAL.. Open DUMPTUBE...AVCR BOOST CONTROLLER... 3 SETTINGS.... 7 PSI, 10 PSI AND 14 PSI.... 7 psi holds boost fine..... 10 psi holds boost fine... ive noticed.. at 14 psi.... my wastegate would open before 14 PSI more like around 9 or 10.. and den goto 14 psi... Is it a faulty wastegate sping...SETTING ON BOOST CONTROLLER.. I am runnin a 7 PSI SPRING.. any info would be great... thanxs
Old 07-04-2006, 10:59 AM
B18 CYA's Avatar
ur boost builds up slowly. it doesn't hit 14 psi instantly. thats what is called lag
Old 07-04-2006, 11:10 AM
Default Re: (B18 CYA)
but wha bout my wastegate opening early.. is that normal? cause i can hear it open.. b4 i hit 14 psi...
Old 07-09-2006, 03:11 PM
Default Re: (afrothunda713)
BUMP
Old 07-09-2006, 04:21 PM
adseguy's Avatar
What are you using to control boost? Are the settings on the EBC (assuming it's an EBC) correct?
Old 07-09-2006, 04:30 PM
Snafubmx234's Avatar
That's fairly normal when you hit about twice the stock WG spring setting. Upgrade to a 10 psi spring and you shouln't have the problem
Old 07-09-2006, 08:02 PM
adseguy's Avatar
Default Re: (Snafubmx234)
I'm not sure if that's true on a Electronic Boost Controller, EBC, since pressure is added to the top of the wastegate to push down on the diaphram and equalize the pressures in the diaphram.
You are right about that for a Manual boost controller though
Old 07-10-2006, 08:21 AM
Default Re: (adseguy)
hmmm.... ima get a 10 psi spring anyway... before i retune.. i am uping the boost to 17 psi...do any of you have the problem of open wastegate early?
Old 07-10-2006, 08:35 AM
Tchleung's Avatar
Just paly with the duty cycle on the boost solenoid some more. Prolly jsut incorrect settings
Old 07-10-2006, 08:43 AM
liquidmetal's Avatar
my wastegate wont open, i turned my boost controler way down, EBC profec b II and it sitll over boost i think its my waste gate, its a shitty delta
Old 07-10-2006, 09:40 AM
Tchleung's Avatar
Liquidmetal - d/c the boost controlelr and run off wastegate spring. That will eliminate weather or not it's your EBC
AZNracerx1989
07-18-2005 10:12 AM
Turbo-charged
04-01-2005 08:32 AM
G U E C O
12-09-2003 02:43 PM
yusoslo
07-12-2003 08:01 PM
b00stedbyFastrax
07-15-2002 05:27 PM
Quick Reply: WASTEGATE OPENING EARLY....
