Boosted GSR Build; Specs, Dyno, Pics Inside
Old 11-26-2009, 08:33 PM
Tulo's Avatar
Default Boosted GSR Build; Specs, Dyno, Pics Inside
Benson Sleeved 83mm B18C1 Built By Slowmotion Motorsports in Sunbury, Ohio
CP 9.0:1 Pistons
Manley Connecting Rods
Stock Crankshaft
Cometic Headgasket
Underdriven Fluidamper with AC/PS Delete
Supertech Titanium Valve Train
Stock GSR Cams and Cam Gears
Mild Port & Polish
Full-Race Intake Manifold
BDL 70mm Throttle Body
MSD Distributor w/ Blaster Coil and Plug Wires
NGK BKR7E Spark Plugs
C&R Visteon Radiator w/ 10" Pusher and 12" Puller Slimfans
Slowmotion 3" Aluminum Charge Pipe Kit
Presicion 825 Intercooler
Dual HKS SSQV Blow-Off Valves
Slowmotion Top Mount Manifold w/ Calico Coating
Full-Race GT3567R w/ .82 A/R HPC Coated Exhaust Side
4" Open Downpipe w/ Calico Coat
Tial 44mm Wastegate
Slowmotion Dumptube w/ Calico Coating
Precision 1000cc Injectors
Slowmotion Fuel Rail
Walbro 255lph HP In-Tank Fuel Pump
Stock Fuel Feed & Return Lines, Pressure Regulator, and Filter
Hondata s300
Corey Parrish Tuned at Slowmotion Motorsports in Sunbury, Ohio
http://www.slomomotorsports.com/foru...hp?f=33&t=1757
94 Octane @15psi - 450whp/295wtq
C16 @25psi - 603whp/401wtq
Need to do the dual Walbro In-Tank and then C16 @33psi = 7xxhp? Hopefully!
Old 11-26-2009, 08:38 PM
93turbo16's Avatar
Default Re: Boosted GSR Build; Specs, Dyno, Pics Inside
Very nice setup.
I definitely like the engine bay.
Old 11-26-2009, 09:09 PM
integrawow's Avatar
Nice build overall man.
Oh, and C16 ftw
Old 11-26-2009, 09:16 PM
reactiondc2's Avatar
looks super clean!! good job!
Old 11-26-2009, 11:15 PM
jdm inc's Avatar
super clean motor! keep it up very nice!
Old 11-26-2009, 11:52 PM
grndcont's Avatar
nice! about to install the same brakes.
Old 11-27-2009, 12:36 PM
Tulo's Avatar
Thanks for the comments! I have since cleaned up/organized the engine bay a little more so I'll hafta see if I can dig up the pics.
Old 11-27-2009, 12:45 PM
FRANKBUILT's Avatar
Super clean and great power!
Old 11-27-2009, 01:43 PM
YARO.'s Avatar
Loving it!!!
Old 11-27-2009, 01:52 PM
boostedEF91's Avatar
looks good man.. cait wait to see what it makes on 33psi..
Old 11-27-2009, 02:34 PM
PrecisionPerformanceParts's Avatar
Engine bay looks great. Do you have any type of crank case ventilation?
Old 11-29-2009, 09:02 PM
tegman23's Avatar
Was just wondering the same thing if you have any blow by issues? Love the topmount...looks great!!
Old 11-29-2009, 09:11 PM
V-SPEC 1's Avatar
do you have pics of the calico coating manifold/downpipe/tube? I'd like to see what they look like w/ those coatings and how the coating holding up? thanks.
Old 11-30-2009, 05:56 AM
Boosted-EH-804's Avatar
Very nice that Calico coating is pretty bad *** which coating is this?
Old 11-30-2009, 07:59 AM
Tulo's Avatar
The coating has held up very well!
Old 11-30-2009, 08:14 AM
official honda whore
EARLdaSQUIRREL's Avatar
anything for crankcase blowby? very nice setup and sick power
Old 11-30-2009, 09:33 AM
Tulo's Avatar
No issues so far, but 95% of the time I'm trolling around on low boost.
I'm saving up to do a similar catch can set-up that Slowmotion did for another customer's built LS.
Old 11-30-2009, 10:36 AM
d16z6Tcrx's Avatar
YES!!!! glad to see im not the only one making power on mount inserts!!
Old 11-30-2009, 11:33 AM
System Lord's Avatar
beautiful setup I have a similar setup on e85 not pushing your numbers yet tho im being conservative at 9 psi at the moment
Old 11-30-2009, 12:57 PM
slowboost93's Avatar
what dont u try Q16 instead of C16 to see what the power differences is
Old 11-30-2009, 04:10 PM
ebp 99 si's Avatar
u could eat off the valvecover...lol
thats a nice setup that makes good power
i have the same brakes on my car
Old 11-30-2009, 04:25 PM
A.E Motoring's Avatar
very nice!
Old 11-30-2009, 05:44 PM
2.0 and up's Avatar
get better cams....ctr's, sk2stg 1 etc... why the dual ssqv's?
Old 12-01-2009, 08:27 AM
ebp 99 si's Avatar
what size wheels/slicks do you plan on using on the car
i couldn't fit 13's cuz of the willwoods, i used 14" bogarts with a 1/2" spacer to clear the brakes
Old 12-02-2009, 06:19 AM
DA TeG 90's Avatar
33psi and better cams "Blox, or Skunk2" you will easily net 650-700 all day. Prob will need 1200cc as well.
Are you running a tiwn disk?
Quick Reply: Boosted GSR Build; Specs, Dyno, Pics Inside
