Is the throttlebody plate supposed to be totally sealed when closed?
Old 08-11-2006, 06:10 PM
* B A N N E D *
crxsiperf's Avatar
Default Is the throttlebody plate supposed to be totally sealed when closed?
Is the throttlebody plate /butterfly supposed to be sealed when idleing, and the car stays running solely by the IAC valve? Im having problems with my idle with my throttlebody and i need to know if my butterfly plate is not completely sealing or if its somethig else , its an aftermarket throttlebody .
Old 08-11-2006, 06:12 PM
DaveF's Avatar
Default Re: Is the throttlebody plate supposed to be totally sealed when closed? (crxsiperf)
do you have a high idle ??
what is wrong with the idle ?
Old 08-11-2006, 07:00 PM
N20civicB18's Avatar
it should never be fully closed as it would bind and make for a harsh enguagement. take your throttle cable off and turn the part where the cable goes back to see if it fixes it
Old 08-12-2006, 10:38 AM
* B A N N E D *
crxsiperf's Avatar
Default Re: Is the throttlebody plate supposed to be totally sealed when closed? (N20civicB18)
Well the thing is , if i hold the throttlebody up to the light i can see light the entire way around the plate , meaning a good bit of air can go through there. Its a bdl throttlebody , 68mm , i may just get an edelbrock or something
asocallocal
09-23-2010 06:20 PM
Car Tweaker
09-13-2009 08:28 PM
nemesiskrp
04-20-2009 08:43 PM
crxsiperf
08-12-2006 10:39 AM
crxsiperf
02-02-2006 09:03 PM
Quick Reply: Is the throttlebody plate supposed to be totally sealed when closed?
