blue smoke coming out breather/oil catch can filter at idle ls vtec turbo
Old 07-02-2011, 04:23 PM
egcoupe007's Avatar
Default blue smoke coming out breather/oil catch can filter at idle ls vtec turbo
at idle lil bit of blue smoke coming out the breather tank filter
Old 07-02-2011, 08:18 PM
civickiller's Avatar
Default Re: blue smoke coming out breather/oil catch can filter at idle ls vtec turbo
rings
Old 07-03-2011, 02:03 PM
egcoupe007's Avatar
is that whats causing more blow by pressure
Old 07-03-2011, 07:27 PM
boostedteg909's Avatar
blue smoke out of the breather is a good indicator that the rings r done. bad rings will cause abnormally high crankcase pressures as well. but if its only the high case pressure u may not hav a sufficient crankcase vent system. an easy way to check ur rings is jus do a compression test
Old 07-03-2011, 07:31 PM
turbonetics3597's Avatar
yeah hes right rings it will soon start running like it has a misfire, if you didnt drive it to much you may not even to bore it just a good hone
Old 07-03-2011, 08:46 PM
i had an issue wit my stock pistons. the ring lands broke off nd decided to make there own lil home in my cylinder wall. the best thing u can do at this point is stop drivin it till u kno exactly wats wrong nd jus fix it. itll sav a lot of time nd money in the long run
Old 07-04-2011, 12:51 PM
egcoupe007's Avatar
if they are bad rings would that reduce my 426 wheel horse power because so much blow by. and say if it is bad rings because high pressure and i vented out more then will i still produce the same 426 wheel horse power and extend the life of the motor a lil bit longer. cuz at this point i don't care anymore i'm willing to ride it as is till it dies.
Old 07-04-2011, 12:55 PM
egcoupe007's Avatar
i appreciate all your answers fellas thanx
Old 07-04-2011, 01:05 PM
well lets put it this way, it doesnt matter wat u do to the gasses after the fact. if u hav excessive blow by...ur losing power. u dnt hav as much force pushing down on the piston as u would wit a good sealing cylinder. its basically wasted horsepower
Old 07-04-2011, 10:34 PM
egcoupe007's Avatar
thanx man
Old 07-05-2011, 07:08 PM
blackeg's Avatar
does anyone know how to spell properly anymore? holy ****.
the last time i had burning oil coming out of my breather my pistons had expanded and scored the cylinder walls.
it was knocking pretty audibly between 2000 and 3000 rpms. i limped it home but the motor did need to go .020 over
Old 07-05-2011, 07:28 PM
hey! leave our grammar alone!! haha
when i had my ring lands fail i had to go 1mm over. it sucked findin pistons for the thing
Old 07-06-2011, 06:47 AM
blackeg's Avatar
sorry man i'm a teacher, its a force of habit i guess.
a good leakdown test will show you exactly what part of the cylinder or which cylinder is bad
emarian
23
04-13-2013 11:02 AM
DumpdEJ6
04-25-2010 08:35 PM
musclefella
02-27-2006 11:20 AM
bQQsted hybrid
05-27-2002 08:44 PM
Cyber ITR
01-07-2002 05:10 PM
Quick Reply: blue smoke coming out breather/oil catch can filter at idle ls vtec turbo
