best oil for turbo motor - Honda-Tech
Old 07-11-2010, 11:22 PM   #1
bLu92bUbbLe's Avatar
Default best oil for turbo motor
ive been running synthetic 5w30royal purple since ive been all motor...now im turbo...so my question is...whats the best oil for the turbo motor...i was told 10w40...what oil are u running and why?
bLu92bUbbLe is offline   Reply With Quote
Old 07-13-2010, 12:08 AM   #2
Default Re: best oil for turbo motor
bump
phelpsj2 is offline   Reply With Quote
Old 07-13-2010, 12:25 AM   #3
jdm inc's Avatar
brad penn http://www.t1racedevelopment.com/en/...acing-oil.html
BRAD PENN® Penn Grade 1® Racing Oils contain highly effective detergent and dispersant additives to guarantee exceptional engine cleanliness as well as oxidation and foam inhibitors that offer protection against thermal degradation and air entrainment. In addition to their unique base oil cut, increased concentration of “zinc” (zinc dialkyldithiophosphate a.k.a. ZDDP) provides outstanding anti-wear/anti-scuffing protection for engines employing either ‘flat tappet’ or roller cams. BRAD PENN® Penn Grade 1® Racing Oils have been evaluated by a number of premiere camshaft manufacturers with tremendous success. We here at T1 Race Development have seen an increase in cam and rocker life while using BRAD PENN® Penn Grade 1® Racing Oils. We now offer 10w30, 20w50, and the break in specific oils.
jdm inc is offline   Reply With Quote
Old 07-13-2010, 02:53 PM   #4
Depends on your bearing clearances. With ACL race bearings I ran 20w50 for years. Some say it's too thick but I had zero issues
E85B18 is offline   Reply With Quote
Old 07-13-2010, 02:58 PM   #5
Motul oil.
CDecker0218 is offline   Reply With Quote
Old 07-13-2010, 03:06 PM   #6
2000CTRSi's Avatar
10-30 or forty... thicker oil is better on high revving turbo cars imo
2000CTRSi is offline   Reply With Quote
Old 07-13-2010, 05:45 PM   #7
Just Another Mod on H-T
EsotericImage's Avatar
^^ +1
remember to change your oil every 1000 miles. Advanced auto has filter and 5qts oil for 17.00. and i change mine once a month..
Just another expense w/ premium fuel to keep our boosted rides going.
EsotericImage is offline   Reply With Quote
Old 07-13-2010, 05:47 PM   #8
00-Civic-Si's Avatar
i change mine every 1000 to 1500 as well
00-Civic-Si is offline   Reply With Quote
Old 07-13-2010, 10:01 PM   #9
joe111599's Avatar
I changed over to Royal Purple about a month ago and about 2-3 days later I spun #4 rod bearing! I totally blame that ****! I turned crank and installed new bearings and went back to Valvoline 10w30 with no issues. I have ran Valvoline for like 10 years no issues on all my cars....N/A and turbo! Never gonna even think about trying something different in the future...EVER! lol. I call that purple crap Royal Pain in the ***! haha.
joe111599 is offline   Reply With Quote
Old 07-13-2010, 11:41 PM   #10
blackcurrantgsr's Avatar
Quote:
How do you know for sure it was royal purple that spun the bearing. On topic I use castrol syntec 10w-30.
blackcurrantgsr is offline   Reply With Quote
Old 07-13-2010, 11:58 PM   #11
99civicsiboosted's Avatar
mobile 1 synthetic 10w30 is what i use and i also change it about every month or so
99civicsiboosted is offline   Reply With Quote
Old 07-14-2010, 12:04 AM   #12
kermit97's Avatar
i used napa 10-30 no issue at all for 5 years.
kermit97 is offline   Reply With Quote
Old 07-14-2010, 05:53 AM   #13
twkdCD595's Avatar
Brad Penn here...
twkdCD595 is offline   Reply With Quote
Old 07-14-2010, 06:42 AM   #14
TorganFM.'s Avatar
Whoa... thousand mile oil changes? Crazy.. I put 5k per change on Rotella T 10-40 for 60k miles, until my head stud broke and screwed the block threads up when changing the head gasket.
TorganFM. is offline   Reply With Quote
Old 07-14-2010, 06:53 AM   #15
Quote:
Same here
Old 07-14-2010, 06:59 AM   #16
Royal Purple 20W-50. I change every 1500-2000 miles.
spoolin99si is offline   Reply With Quote
Old 07-14-2010, 08:29 AM   #17
phatrick2332's Avatar
Changed every 5k.
phatrick2332 is offline   Reply With Quote
Old 07-14-2010, 09:38 AM   #18
sneakysneaky's Avatar
I use rotella synthetic and it lasts a while longer than
normal oil. Normal oil lasts about 1k till it pours like water
for me.
sneakysneaky is offline   Reply With Quote
Old 07-14-2010, 10:04 AM   #19
BlackT5's Avatar
I use Motul 8100, but you could use the 300V if ur a baller
BlackT5 is offline   Reply With Quote
Old 07-14-2010, 02:07 PM   #20
Alot of people say this because RP doesnt carry the "seal of approval" for gasoline engines..I dont use RP stuff, i used the trans additive recently and after the change, it shifts alot worse than before.
Usually most motor oils have this approved seal, this is why i buy the cheap ****. valvoline, castrol, quaker (i dont use quaker state) is cheap, and when u change oil often, your not spending 30-40 per oil change. mine is 17.00 including filter.
Old 07-14-2010, 03:32 PM   #21
brad penn,
I choose it bc of the cam wear agents it contains that other oils don't. If you are running an after market cam I would look into it.
turbo sol is offline   Reply With Quote
Old 07-14-2010, 05:06 PM   #22
cool...so mobil1 synthetic 10w30 or 40 is ok...the thicker te better...i dont rev past 8k
Old 07-14-2010, 05:08 PM   #23
i set the valve clearances oem spec...regular acl bearings...no race...
Old 07-14-2010, 05:10 PM   #24
where do yall buy the motul and brad penn....
Old 07-14-2010, 05:50 PM   #25
b20 turbo stock motor MethHeadCrx Drag Racing 1 06-11-2015 05:20 PM
Advice on best motor oil for use with E85 darkvader0 Forced Induction 28 03-03-2013 07:09 PM
what engine oil to use? jdmcivic2fast Forced Induction 31 10-05-2011 11:49 PM
What Grade Motor Oil? ScuDC5 Forced Induction 13 05-10-2006 03:12 PM
HELP....stupid newbie question lucidvtec Forced Induction 8 06-29-2005 10:24 PM
Tags
20w50, b16, cars, castrol, change, engine, high, honda, motor, motors, motul, na, oil, revving, run, synthetic, thick, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
