Best oil for turbo? 10W-30 Mobil1 Tri Synthetic?
Old 05-09-2002, 08:34 PM
Ri5e's Avatar
Default Best oil for turbo? 10W-30 Mobil1 Tri Synthetic?
I was wondering whats the best oil to use? I heard that 10w-30 mobile 1 try synthetic is good and is thin and lubricates well. Also it makes the turbine spin faster.
What does everyone use? Thanks.
Old 05-09-2002, 09:32 PM
intekragsr's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (BG Boost)
I use that too.............but I also heard synthetic is not good for turbo and is the reason some people blow seals since it gets past them cuz of the thin-ness of the oil. I dont know how accurate this is.
Old 05-09-2002, 10:14 PM
zojirushi's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (intekragsr)
all the reason to use castrol gtx. hell of alot cheaper too. i'll probably try using castrol gtx when i put my stuff in. i don't see how there is a difference
Old 05-09-2002, 10:21 PM
sushibug's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (zojirushi)
im using 10w-30 castol synthetic right now.
Old 05-09-2002, 10:28 PM
Hammett's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (sushibug)
Has anyone use Amsoil?
Old 05-09-2002, 10:49 PM
PrecisionH23a's Avatar
i am a mobile 1 use also, its good ****
Old 05-09-2002, 10:54 PM
93LSivic's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (Hammett)
I am about to try Amsoil. My friend with a 600+ hp supra uses it. His tuner -Bullish Racing-- highly recommends it, for waht reason im not sure. But they use it in their 1000+ hp supra and also in their new 1300+ hp solara's. Im sure its some good **** if they run it and also recommend it.
Im coming up on my first oil change after going turbo (1500 miles). I think Im gonna go with Amsoil.
The oil I am running now is the Castrol blend. It seems to do a good job. I check my oil every day, and after 1300 miles its still as clear as the day i put it in.
Old 05-09-2002, 10:55 PM
Flamenco-T's Avatar
honeslty IMHO, I'd rather blow an oil seals on the turbo than taking chances on internal parts...
just my $.02
Old 05-09-2002, 11:09 PM
New User
turbod97ex's Avatar
I have used Amsoil since I installed my turbo last July. It's great stuff. The one I use is the racing multi viscosity synthetic, 20-50, which is great because of the extreme heat an oil cooled turbo charger puts out. I buy directly from Amsoil and buy 4 gallons at a time. My last order was $150 because I bought an oil analysis kit they sell too.
Old 05-09-2002, 11:14 PM
sushibug's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (turbod97ex)
i was told by my auto-tech teacher that i shouldnt put in 20w-50 in my car.... whats the pros and cons to it?
Old 05-09-2002, 11:16 PM
Snafu-Si's Avatar
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
One question, 5 different answers. We are well on our way to figuring out the right answer.
Old 05-09-2002, 11:28 PM
New User
degradated's Avatar
What's the deal with Mobil 1 synthetic lately? I remember reading in the forums that as of like April 15th, they were changing the formula and it wasn't going to be "true" synthetic anymore. I looked at the Mobil1 website and it did confirm that they were changing it - "All New and Improved!!"....Well, was it truly improved or were the rumors true?
Old 05-10-2002, 12:39 AM
inspyral's Avatar
What kind of oil cooler is that?
Old 05-10-2002, 11:04 AM
b00stedsi's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (degradated)
Well this is what ive heard, mobile changed its formula because of castrol. Castrol claimed to be just as good or if not better than moblie 1 tri syn. So they sat on the shelfs together, one was cheaper so people purchased castrol.. So mobile got pissed and changed the formula to something that cost less to produce.
Old 05-13-2002, 06:51 AM
Slick GS-R's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (inspyral)
that is a greddy oil cooler (good chit)
and for an answer for the original question.......................would mobil 1 tri-synthetic 10w-50 be ok for my ride (99 gs-r turbo)?????
Old 05-13-2002, 07:09 AM
DA666's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (Slick_GS-R)
i think that synthetic is too thin as well...i remember when a professional mechanic/ friend of mine pulled a block apart, only to see saturated synthetic oil glazed to the block, he ended up having to pressurize it off, with i guess steam and pressure, and it took him approx.4-5 just to do that.
people have said it cakes ur internals, which is good if u leak all of your oil out and run around not knowing it for a lil while..........
so, in conclusion, i will never run it, only redline synthetic in my trans.
Old 05-13-2002, 08:39 AM
filetofit
Guest
Posts: n/a
viscosity issues aside, put some synthetic in a frying pan with a candy thermometer and in another frying pan put some regular oil. Synthetic can go over 600 degrees F before it starts to smoke. You'll burn up regular oil at 300-400 degrees.
Old 05-13-2002, 09:36 AM
chameleon's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (filetofit)
gotta love the honda-tech's!! to ya!
Old 05-13-2002, 10:12 AM
*Boostwerks*'s Avatar
Mobil 1
There was a test Mobil 1 performed with a BMW M3 and a dyno several years back to test it's new synthetic oils.
They ran it for over a million miles on a dyno for one year, and then performed a internal engine break down to see how things turned out. They only stoped it every 5,000 miles for an oil change.
The engine looked PERFECT!!. The berrings were still in great shape, and the piston rings were perfectly fine!! IT BURNT NO OIL!!
That's why I use Mobil one.
There is a web page of the test but I don't have the link. Anyone?
Old 05-13-2002, 10:24 AM
modvp's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (Bryson)
I've being using castrol syntec 5w 50 and lately 10w 40 for over 80K miles on my integra RS with Drag III (9psi max). No problems thus far. My compression has remained the same 190+.
Old 05-13-2002, 10:44 AM
New User
VaporTrail's Avatar
I use and recommend regular dino Mobil oil. I have had several people try to convince me on Mobil 1, Amsoil, and other brands, and I could never justify the cost. Just change your oil regularly, use a quality filter, and you should be ok IMHO
Old 05-13-2002, 11:12 AM
New User
turbod97ex's Avatar
This is the reason I use synthetic and an oil cooler. The oil cooled and lubricated turbo engine gets very hot and so does the oil. If you want to use dino oil, I strongly suggest using an oil cooler.
Old 11-04-2002, 10:36 PM
PandaBear's Avatar
Mobil 1 is still a real synthetic ( Group 4 PAO & Group 5 Ester base stock ) unlike most other "synthetic" out there that uses hydrocracked dino oil ( Group 3 ). It last much longer, my car change oil every 10k miles now and the oil analysis shows that it is still usable for a little longer. My 8.2k result with SuperSyn show less than 1 ppm of metal wear per every 1k mile driven, compare to 2-3 ppm on universal average.
Castrol Syntec, Vavoline SynPower, and Penzoil synthetic are all Group 3 only. I used to use Syntec but switch to Mobil1 when they change their formula back then.
Old 11-04-2002, 11:45 PM
wHOAlly's Avatar
thers a article somewhere with a dude and some domestic truck (ford? chey? i forgot), he drove the car 800+ miles daily (he delivered ****) and changed his oil every 3 k miles, he did like over a million miles or something in a few years, he went through liek 2-3 trannies and other maintenence parts, but the block was stock, penzoil heard about it, and bought it and tore it down to see if they can learn from it, they said it only showed signs of about 80k of wear and tear...the dude used penzoil DINO oil....the $.98 ****! so a search, im sure u can find the article.
Old 11-04-2002, 11:58 PM
austrian type-R's Avatar
Default Re: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic? (AkumaY)
Castrol RS 10w60
Quick Reply: Best oil for turbo? 10W-30 Mobil1 Tri Synthetic?
