ITR Cam lobe worn? Normal?
Old 05-07-2008, 12:21 PM
StolenTeg's Avatar
Default ITR Cam lobe worn? Normal?
Modified by StolenTeg at 7:09 PM 7/27/2008
Old 05-07-2008, 01:51 PM
StolenTeg's Avatar
Default Re: ITR Cam lobe worn? Normal? (StolenTeg)
anyone?
Old 05-07-2008, 01:53 PM
Evilparadize's Avatar
I just got some 97-99 ITR's and the lobes look like that, but those cams look like 94+ GSR's.
Old 05-07-2008, 01:57 PM
StolenTeg's Avatar
Default Re: ITR Cam lobe worn? Normal? (Evilparadize)
Hmm so it normal for them to have that uneven slope? that is weird, it look like the rocker eat away the cam lobe
EDIT: I did post a gsr cam head, mistake replace with the itr head now
Old 05-07-2008, 01:58 PM
morgan@synapse motorsport's Avatar
im guessing that it on the exhaust cam. aggresive valve springs tend to do that. was this on stock valvetrain?
Old 05-07-2008, 02:01 PM
StolenTeg's Avatar
Default Re: (mike@synapse motorsport)
I have no idea what valve train was use since i just receive these, am i going to have problem with it like that?
Edit, one of the Intake lobe is like that, exhaust show sign of it too
Old 05-07-2008, 03:12 PM
riceball777's Avatar
Default Re: (StolenTeg)
same thing happen to my itr cams after 100k miles. i ended up buying new 00+ctr cams to replace them.
they are junk and are probably less agressive than stock obd 0 b16a cams. just fork out the money for new itr cams for some skunk2 stage 1's
Old 05-07-2008, 04:59 PM
StolenTeg's Avatar
Default Re: (riceball777)
Bleh that suck that these are junk , i was hoping i can salvage them
Old 05-07-2008, 06:39 PM
batboyvaj's Avatar
https://honda-tech.com/zerothread?id=2008331
this may help you also. the new oil's of today really are not that good for our old motors.
Old 05-08-2008, 11:01 AM
Default Re: (batboyvaj)
All the VTEC lobes and some secondary lobes on both the intake and exhaust look just like. So this has nothing to do with duration? If not, then I boght $300.00 trash!
Old 05-08-2008, 12:40 PM
h22 civic's Avatar
Default Re: (Evilparadize)
yea you will get that wear from aggresive spring rates or a bad oiling problem ,,,side efects would be lack of power (not much) and possibly droping a valve
Old 05-10-2008, 09:27 AM
Default Re: (h22 civic)
Does that wear occur when the valve opens or when it closes? How much power loss is expected? All the VTEC lobes on both intake and exhaust cams look just like that and some on the secondary, would my B16 cams perform better than the 97-99 ITR cams I just bought?
Old 05-10-2008, 10:34 AM
Turbogixxer's Avatar
Is it a stock ITR head?
Old 05-11-2008, 09:35 AM
Default Re: (Turbogixxer)
B16A2 stock head and block. Well head has 5-angle VJ, dual springs & T retainers, P&P and .5 over exhaust valves. T3/T4 is going in soon and I purchased 97-99 ITR cams to compliment the head but if the worn lobes don't do a thing and the cams are trash, then I just spent $300.00 on paper weight.
Old 05-11-2008, 09:39 AM
reactiondc2's Avatar
sad to say but id toss those...from the looks of it they will eat your rocker arms if you attempt to use them
Old 05-11-2008, 10:01 AM
Default Re: (reactiondc2)
Sh*************t! Anybody wanna buy $300.00 worth of paper weight?
Old 05-12-2008, 01:09 PM
extralargenog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evilparadize &raquo;</TD></TR><TR><TD CLASS="quote">All the VTEC lobes and some secondary lobes on both the intake and exhaust look just like. So this has nothing to do with duration? If not, then I boght $300.00 trash!</TD></TR></TABLE>
I HAD THE EXACT SAME **** HAPPENING TO MY BUILT H22 Head went [freak]ING NUTS trying to figure it out... read LOTS about oil, and the lack ofZinc dithiophosphate, I changed to Royal Purple (which has it and theyre own synerlac additive)... Not one problem in over 6000 miles. I was going through exhaust vtec rockers and cams every 1500 miles....
NO PROBLEMS AT ALL ANYMORE.....
I read ALOT on bobistheoilguy and a couple other oil related boards, then found this:
http://www.animegame.com/cars/Oil%20Tests.pdf
It was enough to get me to try it.
SERIUOUSLY... NO ONE COUYLD GIVE ME A STRAIGHT ANSWER... Glad I figured it out myself. I had PLENTY of oil pressure... Changed the oil every 1500 miles, and still had problems with mobile 1. s long as you get the german manufactured **** that has the zincdithiophosphate youre good. EPA standards killed it off in a majority of oils over here that are domestically produced.
TRY IT... you WILL be happy. Another friend tha I know was having the same **** happen... Told him about my ordeal, and the Royal purp... Its more than hype (not to mention it actually micropolishes blemishes).... It WORKS.
Period...
Modified by extralargenog at 2:14 PM 5/12/2008
Mike K
02-13-2007 10:54 PM
turbo gsr
10-05-2005 01:26 PM
lilxvtecxpwr
04-05-2004 07:01 PM
VtecNit01
12-24-2001 06:11 PM
Quick Reply: ITR Cam lobe worn? Normal?
