B20 cams for LS turbo?
HELLO,GOOD MORNIN'
Re: B20 cams for LS turbo? (silver_nteg)
I've seen no noticeable difference. maybe a little to none. It think the duration is bigger by a tad. But I'm not even for certain on that.
Re: B20 cams for LS turbo? (HybridcivicLS-T)
I had them in mine, if I remember right the lift is slightly more on the B20 cams. There won't be and "real big help" or whatever though.
Antwon, wtf do you know about B20 cams man?
Re: B20 cams for LS turbo? (ApexiChild)
As far as I know the B20 cams are not better then the LS ones. I know that 92-93 LS cams are wee bit hotter then the B20 cams. The only difference in the 90-91 LS motors and the 92-93 is the cams. Thats why the motors make 10 more HP supposedly. Just my 0.02 cents tho. If you plan on putting cams in your LS/B20 you should get some cams from Rocket. (IM him, he will hook you up) He makes some sweet cams for LS/B20 at very resonalbe prices, plus you get really good tech support as well. The cams are great for FI, if you tune em with some cam gears they lay down some impressive #, just ask Jalopy SiR.
Blaze
Blaze
HELLO,GOOD MORNIN'
Re: B20 cams for LS turbo? (HatchbackComeback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchbackComeback »</TD></TR><TR><TD CLASS="quote">I had them in mine, if I remember right the lift is slightly more on the B20 cams. There won't be and "real big help" or whatever though.
Antwon, wtf do you know about B20 cams man? </TD></TR></TABLE>
Alot more than you..........
Watch it....you're "The TURBO Baby" for a reason!!
And let's not forget the guy that was nice enough to swap your motor for you
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchbackComeback »</TD></TR><TR><TD CLASS="quote">Watch it....you're "The TURBO Baby" for a reason!!
And let's not forget the guy that was nice enough to swap your motor for you </TD></TR></TABLE>
Great comeback.
Great comeback.
