B16a Turbo Setups
Old 01-04-2014, 07:42 PM
  #1351
89efhatchy's Avatar
Default Re: B16a Turbo Setups
Originally Posted by TheShodan
3rd gear at 22psi makes a bit more sense for the 4800rpms. I was referring to that boost pressure in the usual Dyno 4th gear. With a divided housing, it only seems "better" because of the massive 80mm exhaust wheel that you're using. Since its only for drag racing use, "spool" wouldn't be as relevant anyway.
Let for a response, but a good response you made.. ..
The car never saw 22psi on the dyno. Boost control wouldn't work when we tuned it. I was just stating what it did on the street. However, we use a loaded mustang dyno so 4th would have shown a slightly quicker spool time. I'm not sure what you mean by it "seems better". I simply stated what it did. Quite a bit more responsive than I expected it to be. I took it down the road on the 66mm today and it honestly didn't feel much laggier. I was watching the wideband so I didn't get any real data as far as spool goes. It should still have a pretty broad powerband though, especially for drag racing.
Old 06-08-2014, 05:37 PM
  #1352
89efhatchy's Avatar
Little video of my b16 car on 235/60/15 m&h's.
Old 06-08-2014, 06:49 PM
  #1353
b16racereg6's Avatar
Looks like fun!!!
Old 12-22-2014, 05:45 AM
  #1354
hunterac12's Avatar
New to the honda game (ex subie boy stupid headgaskets) im looking to boost my civic when i get more money but i want to do it right like build internals and then boost it because reliability is key. would anyone be willing to make me a list of parts i would need? sorry for my noobiness. has y21 lsd trans with stage 2 clutch and h sport axles so not to worried about trans just motor work. Or how much boost can a stock block hold safely. lets just say out of a 40 or 50 trim.
Old 06-15-2015, 05:02 AM
  #1355
s2k drifter's Avatar
Anyone currently running a b16 turbo with AC and PS? If so what set up did you go with and did you come across any issues?
I'm thinking about boosting my Em1 (b16a2) and power goal is 250-300 hp on stock internals.
Old 06-19-2015, 09:00 PM
  #1356
y7civic's Avatar
I am currently running an Greddy 18g turbo kit on my B16a2 ARP head studs stock internals. The downpipe on this kit has restrictions on the exhaust elbow to the exhaust. I am running a custom 2.5" downpipe, however the exhaust elbow doesn't help. I am currently at 220 whp at 10 psi.
The problems I ran into are heat soak on my A/C condensor from the turbo. I was unable to keep the stock condensor fan due to the custome support brackets I made. I wrapped the log manifold with exhaust wrap, and made an custom heat shield with tunnel wrap under the heat shield. I also used a td05 turbo blanket from a wrx they all helped and reduced the temps umder my hood. I installed a blox 12" fan in front of the condensor.
I also had cooling issues when I switched to the fal slim fan I ended cutting the center of the thermostat out and problem solved. I have no power steering clearance issues. I hope this helps.
Old 06-20-2015, 12:00 AM
  #1357
Who is Mr Robot?
wantboost's Avatar
Told you. Heat soak is a huge problem on turbo Hondas with AC
Old 06-22-2015, 11:00 AM
  #1358
Originally Posted by y7civic
You did a nice job with with your set up.
Old 06-25-2015, 12:14 AM
  #1359
hondab16iceland's Avatar
I haven't gotten my whole setup but it's on the way to Iceland
Stock b16a2
Ebay turbo t3/t4 57 trim
Ebay intercooler
Go autoworks Cast iron manifold
Go autoworks Downpipe
Tial 38mm wastegate (7lbs spring)
Turbo XS bov
Go autoworks Grams 550cc injectors
Go autoworks Grams 320 lph fuel pump
Also few gauges from GoAutoworks (Oil pressure/Wideband and Boost with overboost warning)
p28 gonna have it tuned for my setup until i get Neptune or Hondata so i can have high 12psi to begin with and low boost 5-6psi
btw can someone tell me what hp i'll be close to? No dyno in Iceland thats good..
Hoping for low 13's on 12psi
Old 06-25-2015, 05:06 AM
  #1360
mellul05290's Avatar
B16A2
Wiesco Pistons
Eagle Rods
ACL Race Bearings
Precision 5831 entry level journal turbo
CXracing top mount manifold
44mm tial wastegate
3" side exit exhaust
3" coldside intercooler piping
2.5" hotside piping
ebay intercooler
Walbro 255 pump
RC750cc Injectors
Hondata S300v2 ecu
Hondata coil on plug
Standard sleeves
Standard inlet
Standard throttle bodie
Standard fuel rail, FPR, fuel lines
Road legal
Pump fuel
425whp @ 32psi of boost babyyy!
10.56 1/4 mile @ 129mph 1.56 0-60ft
Budget drag car!! Check my thread
Old 06-25-2015, 08:06 AM
  #1361
Originally Posted by mellul05290
B16A2
Wiesco Pistons
Eagle Rods
ACL Race Bearings
44mm tial wastegate
2.5" hotside piping
ebay intercooler
Walbro 255 pump
RC750cc Injectors
Hondata S300v2 ecu
Standard sleeves
Standard inlet
Road legal
Pump fuel
Holy ****. Now i need to think about getting stronger pistons, rods and bearings! Got pic of your setup ? You using stock axles?
Old 06-25-2015, 09:02 AM
  #1362
Yeah stock drive shafts mate and some rusty lower arms and bushes!
Old 06-25-2015, 09:11 AM
  #1363
BigBerz's Avatar
My B16A2 lasted not even 3 months (stock internals) before the ringlands broke and I needed a new block. I wouldn't recommend boosting a stock Bottom end B16A2 to anybody. I ran 13.14 on street tires.
Berz out.
Old 06-25-2015, 10:05 AM
  #1364
ls joker's Avatar
Berz out.
was your engine healthy and professionally tuned. most peoples setups dont usually just go out in a short time frame. not that i dont believe you but, i feel like theres alot of info left out
Old 06-25-2015, 10:46 AM
  #1365
BigBerz's Avatar
I did run Nitrous before it was boosted but in the end ring lands are the weak point in those motors. It was probably just over use and hard driving coupled with the nitrous and then turbo but still, failure is failure.
Berz out.
Old 06-25-2015, 03:43 PM
  #1366
Moderator
TheShodan's Avatar
Berz out.
hmmm. not really sure that can be an accurate generalization. 320whp on a b16 for 7 years, daily driven 13psi of boost pressure. About 120Km on the engine. Ringlands are just fine. Doing fine.
Mechanical health of the motor is key to ensuring longevity on any engine.
TheShodan out
Old 06-25-2015, 08:53 PM
  #1367
ls joker's Avatar
i still have my back up engine completely stock jdm b16a. that has seen boost for over a year. never had any problems. all in the tuning and care.
ls joker out
Old 06-25-2015, 09:06 PM
  #1368
ls joker's Avatar
it should
Stock b16a2
Ebay intercooler
Turbo XS bov
315whp or so on that turbo varied by typed of dyno with 93 octana
Old 06-26-2015, 02:43 AM
  #1369
Originally Posted by ls joker
it should
315whp or on that turbo varied by typed of dyno with 93 octana
Great thanx!
Old 04-27-2016, 11:39 PM
  #1370
Typesivtec's Avatar
Default Re: (paul93sir)
Originally Posted by urbansi
99 si with stock bottem end
18g turbo
310cc injectors
uberdata 1.7
street tuned @ 9psi
214.5 hp, 162 tq
13.6@99.8 with a 2.1 60ft
ReLly bro I have a b16a on my teggy whith a s80 hydro trans stock internals all motor on a street tune I'm pushing 210 hp
Old 04-30-2016, 06:34 PM
  #1371
gutted-dx's Avatar
My first time tuning one of my cars.
-GSR head, CTR cams, PeformerX intake
-Stock B16 block
-log manifold, Turbonetics 5454
-Grams 1000cc injectors
-s300v2
I'm slowly reading up hondata and have a boost solenoid with boost option also.
Old 05-01-2016, 06:38 AM
  #1372
ls joker's Avatar
-Stock B16 block
-s300v2
Kool
pinoyk20
11-17-2006 09:00 AM
flangemastermike
05-31-2006 11:51 AM
90b16DA
03-17-2006 06:24 PM
motoman182
01-26-2006 06:06 PM
B16aswap
01-20-2005 02:14 PM
Quick Reply: B16a Turbo Setups
