b16a turbo over heating when A/C is on-*Solved* Replace Radiator!
when the A/C is on the car starts to over heat, If I turn the A/C of it still keeps rising as I've reached a tipping point I guess. without the A/C on the car run's fine no matter how hard I push it.
my setup is more then likely to blame as I have intercooler then fan then A/C radiator then coolant radiator all in a row, not many options when it comes to civic EG's, so wondering if anyone has any idea's on keeping water temps down on turbo'ed b16a's with A/C
re: b16a turbo over heating when A/C is on-*Solved* Replace Radiator!
Bleed system? thermostat opening? I don' t see the a/c lines so this car doesn't look like it has ac
Fish Twig
So more detail, the ac condensor is tucked. I don't see how the a/c has anything to do with your engine overheating. Either its heat soaked and while idle your cooling system was soaking up all that heat. I hope you have the fan circulating properly.
Post close up pics of the condenser, radiator, and their fans. Do the fans work? Does the condenser touch the radiator.
both Fan's are tied in together so they work at two speeds, slow for A/C and fast for temp, so basically they are always on full speed as water temp trumps the A/C using a BMW fan relay module
this is what it looks like "bumper=intercooler=A/C fan=A/C radiator=coolant radiator=coolant fan"
If the radiator touches the condenser or the hot high side condenser line, that could be the problem.
That's a design that obviously can work if there's adequate space and air flow, but they cannot touch each other so that no heat is transferred between them
And shouldn't all fans be on the engine side? I don't think having the condenser fan in front of both the condenser and radiator is a good design. Maybe remove the forward condenser fan and replace with a double strong dual rearward condenser/radiator fan.
Welcome to the world of necessary sacrifices for power. Suck it up and roll the windows down, or get an AC compatible setup. This is a known and accepted fact of our world.
ac compatible MANIFOLD. You really need to make sure its moving air in one direction.
having an A/C compatible manifold just means that its made in a way that you can fit the wastegate and turbo without having to lose the A/C radiator and A/C compressor, that wont stop all that heat from building up down there, I've done what i can with heat shielding down there.
the air is all moving in one direction, i'm sure, I've tested this many times.
if the air flow wasn't doing what it should i would be having overheating problems without A/C as both fan's work at the sametime one pushing and one pulling would make a vacuum in the middle
Fish Twig
Fish Twig
You thermostat may be flushing the coolant at a lower temp, but is your fan switch made to kick on at low temps as well? The fan switch and the thermostat work hand in hand.
Why don't you think your condenser fan may be impeding proper air flow by being located in front of both the condenser and radiator, and also by running at a lower speed than the radiator fan that is located in the correct position?
Not sure where you are located but I had my manifold and DP coated by Swaintech -> White Lightning Exhaust Coatings | Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings. Using an IR gun I measured surface temps at the collector during a pull between 250-300C
Also do you have any ducting? I used sheet aluminum to help keep air from going anywhere but through the radiator.
Hello
i need to know if you have any luck with your heating problem?
By the way I have modified the AC and radiator in raw to keep my AC I am working on turbo project but I haven't installed turbo engine
Thanks
Thanks
yep i fixed my problem by replacing the a/c radiator with a better one, it turned out that the radiator was the problem from the start, just a generic china made universal one that i should never have used it the first place
crxhybrid1320
07-01-2011 06:01 PM
