Any of you guys have issues with Mobil 1s 15W50?
Old 06-09-2005, 10:02 AM
*Boostwerks*'s Avatar
Default Any of you guys have issues with Mobil 1s 15W50?
I decided to try out this oil this season, but so far I don't have my turbo setup installed for emissions. I just have my oil feed line capped off, but with the thicker oil I am now getting ubber high pressures. Cruising above 4K its about 75psi! I'm sure the turbo will lower the pressure in the system, but now I'm noticing that oil is leaking past the seal of my honda oil filter. It's even cranked on there pretty damn good, but oil is just leaking past the seal. Granted this is honda's small *** filter (apparently they discontinued the larger filters).
Anyone have oil problems with these small filters and 15W50?
Old 06-09-2005, 12:08 PM
mrbsponge's Avatar
i have had no issues in fact i was told to run this oil in my otor because of my bearing specs, and the fact that it was turbocharged, i was told it helps with any blow by the turbo may develop as well as heat for the motor and rings.
so far i have been running it for 2 years on my car with no issues, and it works perfect.
maybe you have a small piece of trach on the filter seal or on the block itself???
Old 06-09-2005, 12:25 PM
boostd hatch's Avatar
Default Re: (mrbsponge)
Ive ran it for 5 years now and no problems what so ever, car still dosen't use any oil and is over 300 whp.
Old 06-09-2005, 12:54 PM
tony1's Avatar
Default Re: Any of you guys have issues with Mobil 1s 15W50? (Bryson)
75psi is fine, your oil leak isn't a result of that pressure. Like stated above, probably something wrong with the seal or surface.
Old 06-09-2005, 01:04 PM
porsche997dc2's Avatar
Default Re: Any of you guys have issues with Mobil 1s 15W50? (tony1)
You can try the Honda S2000 oil filter. It's a bigger oil filter.
Old 06-09-2005, 01:12 PM
Sprockets's Avatar
Default Re: Any of you guys have issues with Mobil 1s 15W50? (porsche997)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 &raquo;</TD></TR><TR><TD CLASS="quote">You can try the Honda S2000 oil filter. It's a bigger oil filter.</TD></TR></TABLE>
You beat me to it! 15400-PCX-004, made in Japan by Toyo Roki, and fits the old oil filter tool.
Old 06-09-2005, 01:29 PM
mrbsponge's Avatar
sweet i didnt know that thanks for the info homeys!
Old 06-09-2005, 01:59 PM
Cool I'll try that out.
Yeah, it might just be a faulty seal or something. Before I was running 10W30 mobil1 and I didn't have ANY leaking issues.
Thanks!
Bryson
Old 06-09-2005, 03:32 PM
ComputerJLT's Avatar
just curious; where do you get 15/50 at?
the local town sized wal-mart thing doesn't have 15w50 :-/
Old 06-09-2005, 04:55 PM
beepy's Avatar
Default Re: Any of you guys have issues with Mobil 1s 15W50? (ComputerJLT)
I've ran 15W50 for a year or so now. No problems with oil pressure.
I get it from the local B&B.
Old 06-11-2005, 05:18 PM
vtec.dc2's Avatar
try a larger filter. i run the older poh-305 filter, s2000 is similar size.
i recently did a change to 15w50 and think it was a waste of money.. i had more stable oil pressure using conventional penzoil 15w40.. i don't know whats the deal is but my pressure would normally read 5.1-5.2 kg/cm2 at 4k rpm, now its reading below 5k.. i guess i'll try castrol 5w50 next.. waste of $30. doubt i'll be using any of mobil products again. during winter i use shell 5w40, holds steady 5.1-5.3kg/cm2 pressure
kmaz93da
06-30-2010 01:12 AM
Dubs13
08-01-2009 07:22 PM
Xerxes
08-28-2004 02:02 PM
People_Mover
05-19-2003 01:05 PM
Spade
03-15-2002 06:36 AM
Quick Reply: Any of you guys have issues with Mobil 1s 15W50?
