83mm LS headgasket so hard to find.. - Honda-Tech
Old 03-18-2017, 06:30 PM   #1
Default 83mm LS headgasket so hard to find..
Seems like not many people have ran this set up but i am having the hardest time finding a straight LS gasket in 83mm, i even started considering using a b20 headgasket but the heads are different LS and b20 heads have different coolant holes around the cylinders... there was 3 companies that i know of that make a straight LS 83mm head gasket, one is cometic i use that and it started leaking right away(not using cometic again), second option was supertech their gasket came in today and had some issues with the gasket blocking a few coolant holes, my only other option now is JEproseal..
does anyone else have any other options that i can use? seems like 95% of people that go for big power on 83mm bore run vtec heads.
here is a video for you guys to watch..
Turbo Bseries is offline   Reply With Quote
Old 03-18-2017, 08:25 PM   #2
Default Re: 83mm LS headgasket so hard to find..
Cometic historically makes a quality product... maybe the problem is not the gasket. Also, a few coolant holes being mis-aligned or covered is not a huge deal, and if you really feel that they are in fact necessary, you could trace the missing holes from an OE gasket to the new gasket and then drill them on a press slowly with the gasket placed over a piece of wood so as not to distort it.
JRCivic1 is offline   Reply With Quote
96 SMX B20B Headgasket question? Nacurtis92 Honda Element & CR-V 0 02-23-2017 10:58 PM
FS: BNIB 82mm Cometic Head Gasket JDMCIVIC919 Florida (Sales) 0 05-04-2012 03:23 PM
Cometic or ebay head gasket? joppe Forced Induction 24 07-14-2009 06:50 PM
Cometic Headgasket - The Review Dunc Forced Induction 28 07-14-2008 02:39 PM
Cometic LS/CRVTEC headgasket confusion. boomslang Tech / Misc 4 09-30-2002 04:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
