270 vs 360 thrust bearings...
Re: 270 vs 360 thrust bearings... (Outkast)
360 degree is better, b/c it protects the entire shaft, and not just part of it. it is better especially when boosting higher numbers b/c its more stable.
Re: 270 vs 360 thrust bearings... (-TRINiTRON-)
It transmits the thrust force equally onto the compressor/turbine shaft. At high psi levels the thrust force increase expotentially, so the force isnt transmitted equally giving a expotentially increased wear of the center section.
markvqwerty
01-05-2005 07:45 AM
