Em1 B16 JRSC idles bad and undrivable
Old 03-28-2015, 04:26 PM
JDMEMone's Avatar
Default Em1 B16 JRSC idles bad and undrivable
Hi everyone, like the title says a have a em1 with a B16 and recipe toy just put on a jrsc. The car has 60k initial along with the engine all original. No check engine lights. If the bypass valve is zip tied open the car won't start. I have a fpr on dialed down to 32 psi that's the only way it will start. Tore apart the head thinking maybe I had bad valve or a bad head gasket but still runs the same. OEM fuel system and injectors on OEM P2T ecu. The car is completely urn drivable because if you give it more the 25% throttle it wants to cut cut but if I drops to idle too fast it dies out. Any suggestions? Thank you in advance!
Old 03-29-2015, 01:44 AM
m4xwellmurd3r's Avatar
Get a tune
Old 03-29-2015, 02:39 AM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Em1 B16 JRSC idles bad and undrivable
Oh hey, it's another "I don't understand how forced induction works" thread.
Old 03-29-2015, 06:01 AM
JDMEMone's Avatar
Hey it's another "I'm a F@&$ing *****" posting! I've done plenty a turbo'd and SC'd cars compared to your junk yard turbo D15b sitting in your moms driveway. If you don't have anything insightful to post, then stick to your chat room **** talking.
Maxwell I am just trying to work out the kinks to drive it to get emissions every year, then go back to the tuned ecu.
Old 03-29-2015, 08:13 AM
yungkhmer's Avatar
your not gonna work out any kinks with the stock ecu. wtf.. maybe you should stay n/a.
Old 03-29-2015, 10:08 AM
met
met's Avatar
In your title should said trying to setup to limp to inspection with jrsc, you might have got a better response. Its going to be compromise without a tune. If you have the proper meters afr and a little know how and you keep out of boost might be able to limp by, but at the inspection station no clue. Without a tune you might only be able to do that 25% throttle. I would back the distributor off a few degrees and ensure the afr is good at idle and light driving, other than that your asking for problems. I almost would think it would be better do what I have heard a lot of people do drop a stock engine in for inspection, glad my state has no inspections.
Old 03-30-2015, 01:28 AM
You should pull off all the jrsc stuff and revert everything back to stock if you're trying to pass emissions. Stop trying to rig stuff.
At least then any issues the car has can be traced back and diagnosed as a stock set up and not a rigged up one
Old 04-01-2015, 02:28 PM
wunfstgsr's Avatar
Try a stock fpr!
Old 04-02-2015, 08:07 PM
budman123's Avatar
It was running ok b4 you put jrsc? Mayb you put the plug for MAP and TPS backward? Cuz it happened to me b4. It idles like crap adn will die as soon as i push the throttle. Just an idea.
JDMEMone
Engine Management and Tuning
06-08-2015 06:42 AM
JDMEMone
02-15-2015 10:59 AM
[eg6]
06-11-2009 10:06 AM
miksew
09-29-2003 06:32 AM
Quick Reply: Em1 B16 JRSC idles bad and undrivable
