confused about my oil feed plate size
Old 05-13-2010, 03:12 PM
boarding2008's Avatar
Default confused about my oil feed plate size
I got my turbo in yesterday and hooked the oil drain/feed lines up. Well when I was looking at the oil feet plate (connects line to turbo) the hole the oil has to go thru is like a pin hole. Is that normal. Its a brand new line/adapter. Does it need to be drilled out? If so to what size?
Old 05-14-2010, 07:09 AM
Default Re: confused about my oil feed plate size
Bump
Old 05-14-2010, 10:52 AM
tofast4uh22's Avatar
looks like it has a built in restrictor. what turbo are you running?
Old 05-14-2010, 06:16 PM
A t3/to4e 50 trim. 63ar hot side. Its going on my slightly built d16z6.
Old 05-14-2010, 06:18 PM
I'm shooting for 300-325whp btw
Old 05-14-2010, 06:50 PM
vwbased's Avatar
have a nice day
Old 05-14-2010, 07:59 PM
well it was just rebuilt. But ill gontact garrett and see what they say. I also have a catch can with two fittings on the valve cover then drained to the oil pan.
Honda4life777
09-27-2012 01:13 PM
South Bay Surfer
07-10-2008 10:31 AM
SHystrdyGSRtdy
04-22-2005 07:54 PM
CRAZYHONDA
04-21-2005 06:47 PM
projectxspeed
04-19-2005 03:45 AM
Quick Reply: confused about my oil feed plate size
