***Forced Induction Forum FAQ*** - Honda-Tech
Old 10-15-2004, 10:19 AM   #1
Rory Breaker's Avatar
Default ***Forced Induction Forum FAQ***
Here are some questions we see pop up frequently from time to time. Hopefully this will encourage people to ask more detailed questions rather than some of these bland general questions. It also should give people new to the game a bit better understanding of what things are and how they work. I would also advise everyone to check out http://www.howstuffworks.com and read up on turbochargers, as there is some excellent beginners information there that will at least allow you to understand some of the jargon we use here.
This is going to be a community FAQ. Im getting it started with a few, and encourage everyone to take a little time and post links to information they feel would be valuable in here. Sick of seeing people posting "how much power does xxx make"? Find the answer or write something up and PM a link or writeup it to me, or just post it here. I will check this post periodically and arrange your posts for quick reference.
***DO NOT POST COMMENTS IN THIS THREAD. ONLY POST LINKS/ANSWERS TO CONTRIBUTE TO THE FAQ. IF YOU POST USELESS COMMENTS, WE WILL DEDUCT POINTS AND RESTRICT PRIVILEGES. PLEASE BE RESPONSIBLE WITH THIS. IF YOU HAVE ANY SUGGESTIONS ON TOPICS BUT CANT FIND AN ANSWER, PM ME***
This is OUR forum guys, all of us collectively. Do your part to keep it fresh and interesting by contributing to this FAQ.
We need you guys to post up common questions and a link to answers in this thread, so get to it!
Thanks!
TURBO 101 by Garrett (thanks RTW DC2R):
http://www.turbobygarrett.com/....html
What is in a turbo kit, what do I need?
http://www.cse.uconn.edu/~yele....html
http://www.honda-tech.com/zerothread?id=1263795
Are Ebay/SSautochrome/OBX manifolds any good?:
There are COUNTLESS threads available on this by searching
How to rebuild your turbo(Stealthmode62)
http://www.honda-tech.com/showthread.php?t=1397101
Compressor Maps and Reading them properly:
http://www.honda-tech.com/zerothread?id=142398
http://www.honda-tech.com/zerothread?id=96443
How a turbocharger really works. In depth video from Holset (Thanks to TheShodan)
How a turbo works - YouTube
http://www.youtube.com/watch?v...lated
Turbocharger Myths Busted by Rick Balsy - Ecotec 2.0 Assistant Chief Engineer
https://www.youtube.com/watch?v=O-YdCZ3Hm7g&t=223
Turbo vs Supercharger
Forced Induction - Supercharger vs. Turbo Charger - YouTube
How a turbo is made
How a turbocharger is made - YouTube
Ball Bearing vs Journal Bearing - Courtesy of TheShodan
http://honda-tech.com/showthread.php?t=2838725
Oil Restrictors: Fittings vs Flanges & When One Is Needed:
Oil restrictors: Fittings or Flange style? Multiple turbos destroyed
Which manifold works for me?? Topmount/ramhorn/miniram/log
http://www.honda-tech.com/zerothread/2152865
Do Turbo Blankets actually work?
One less "scientific" video that really does show the main point
Article: Turbocharger heat shields: Fact or Fiction?
http://www.superstreetonline.com/how...-fact-fiction/
Radiator, fans, shrouds, etc - The all-inclusive cooling thread (thanks Hussain-vtec)
http://honda-tech.com/showthread.php?t=3062009
Fuel pump - Name Brand vs Knock 0ff - Flow comparison with Data - (thanks NotARacist)
http://honda-tech.com/showthread.php?t=3196937
Where do I run my wastegate line to? Compressor or IM? (thanks Testudo)
http://www.honda-tech.com/zerothread?id=118699
Common bolt/nut sizes for Honda turbo setups:
http://www.honda-tech.com/zerothread?id=373905
How to decipher Garrett/Precision Turbo Names:
http://www.honda-tech.com/zerothread?id=763809
Turbo vs SC:
http://www.honda-tech.com/zerothread?id=688120
http://www.honda-tech.com/zerothread/2283214
How to tune:
http://www.honda-tech.com/zerothread?id=979788
How can I hook up an alarm and turbo timer?
http://www.honda-tech.com/zerothread?id=1018699
http://www.honda-tech.com/zerothread?id=1328129
What turbo comes in a Drag kit?
http://www.honda-tech.com/zerothread?id=934127
What do I gap my plugs at?
http://www.honda-tech.com/zerothread?id=877602
Whats an Electric supercharger/turbocharger? Any good?
NO.
Buying a used JRSC - what do I look for?
http://www.honda-tech.com/zerothread?id=907454
General JRSC questions/information
http://www.honda-tech.com/zerothread?id=853964
AIR Intake Manifold?
http://www.honda-tech.com/zerothread?id=961203
SSAutochrome/OBX Turbo manifold?
http://www.honda-tech.com/zerothread?id=941816
Whats the difference between a log and equal length manifold (general manifold design info too)
http://www.honda-tech.com/zerothread?id=925312
Hondata or AEM?
http://www.honda-tech.com/zerothread?id=963992
http://www.honda-tech.com/zerothread?id=708650
http://www.honda-tech.com/zerothread?id=612698
http://www.honda-tech.com/zerothread?id=671022
What is A/R?
http://www.honda-tech.com/zerothread?id=1023414
Drag3 Turbo Install:
http://www.honda-tech.com/zerothread?id=635014
How do I break in my motor?
http://www.honda-tech.com/zerothread?id=878397
Dyno comparison: Skunk2 Pro 1's vs CTR camshafts(Jeff Evans)
http://www.honda-tech.com/showthread.php?t=2520138
Smaller turbo + more boost or Large turbo + less boost?
http://www.honda-tech.com/zerothread?id=1004578
Spark Plug Information, NGK #'s and more! (thanks HXMan)
http://www.honda-tech.com/zerothread?id=510127
Everything you want to know about NGK spark plugs (Ladysman)
http://www.honda-tech.com/showthread.php?t=510127
Oil Return Line Assembly (thanks HXMan)
http://www.fast-turbo.com/oilreturnassembly.html
Mounting Oil Lines on Firewall (thanks to B18EG6 & Type-X) :
http://honda-tech.com/zerothread?id=377208
What about EGTs? How important is EGT?
http://www.honda-tech.com/zerothread?id=248965
BSPT/NPT/AN Fittings Explained and Line Info
http://www.honda-tech.com/zerothread?id=364948
http://honda-tech.com/zerothread?id=1226089 (thanks vtec.dc2)
http://www.honda-tech.com/zerothread?id=1312904 (thanks BlueShadow)
How to install AN fittings
http://www.honda-tech.com/showthread.php?t=2150049(B R Fittings)
Why am I getting boost creep/spiking with my Drag manifold?
http://www.honda-tech.com/zerothread?id=856210
http://www.honda-tech.com/zerothread?id=802961
What size IC piping should I use? (thanks BlueShadow and Schister66)
http://www.honda-tech.com/zero...02591
http://www.honda-tech.com/zerothread/2409417
Where do I tap my EGT guage?
http://www.honda-tech.com/zerothread?id=163453
Can I install Hondata and Injectors BEFORE I install my turbo kit?
http://www.honda-tech.com/zerothread?id=98092
What spark plugs do I use on an FI Honda?
http://www.honda-tech.com/zerothread?id=156273
How do I hook up my MBC?
http://www.honda-tech.com/zerothread?id=117513
Installing your Walbro pump
http://www.honda-tech.com/zerothread/2424575
Injector info:
http://www.robietherobot.com/s...e.htm
How do I install DSM injectors? (thanks 93turbo16)
http://www.honda-tech.com/zerothread?id=691345
http://www.honda-tech.com/zerothread?id=195834
http://www.geocities.com/uncgo....html
Resistor Box wiring:
http://www.honda-tech.com/zerothread?id=441107
http://www.honda-tech.com/zerothread?id=517274
GSR Engine Build - How-to and tips: (thanks to Jeff Evans for an awesome writeup)
http://forums.evans-tuning.com...build
The *definitive* AFC Hack thread: (thanks JDavis)
http://www.honda-tech.com/zerothread?id=841443
Uberdata install and tuning information: (thanks keebler65)
http://home.mn.rr.com/keebler65/honda
Information on Catch Cans and how to construct them: (thanks 95gsrcivic)
http://www.honda-tech.com/zerothread?id=766009
http://www.honda-tech.com/zerothread?id=722482
http://www.honda-tech.com/zerothread?id=687222
http://www.honda-tech.com/zerothread?id=684673
...and the official crankcase evacuation thread:
http://www.honda-tech.com/zerothread?id=1199935 (thanks dasher)
How do you setup the AVC-R gear boost?
http://www.honda-tech.com/zerothread?id=1037051
Want to turbo your SOHC? Results!
http://www.honda-tech.com/zerothread?id=1067168
How do I ship my block to get it sleeved? (thanks Testudo)
http://www.honda-tech.com/zerothread?id=629402
CFM vs PSI? Is 7PSI on one turbo the same as 7PSI on another? (thanks dornon13)
http://www.honda-tech.com/zerothread?id=1055905
HOW-TO Install JRSC 92-00 Civic (thanks Enzospeed):
http://honda-tech.com/zerothread?id=1283655
Motorola 2.5Bar Map Sensor Info (thanks 93turbo16):
http://www.honda-tech.com/zerothread?id=1266876
General CRX Turbo Shopping List w/Prices (thanks BlueShadow):
http://www.honda-tech.com/zerothread?id=1157746
Where do I tap my EGT gauge? (thanks Testudo)
Wastegate: Route into DP = loss of power? (thanks Testudo)
http://www.honda-tech.com/zerothread?id=94820
http://www.honda-tech.com/zerothread?id=151845
Tial Wastegate setup -
EBC - Top and Side ; MBC or no BC at all - Side port, leave top open
Turbo Rebuild:
http://www.honda-tech.com/zerothread?id=1397101 (thanks stealthmode62)
Pulling motor tips; remove motor for mild build? (thanks Elpiar)
http://www.honda-tech.com/zerothread?id=1419944
GM 3Bar Wiring (thanks vtec.dc2)
http://honda-tech.com/zerothread?id=1440585
Volumetric Efficiency (thanks vtec.dc2)
http://honda-tech.com/zerothread?id=1025485
Partial Throttle Tuning (thanks elpiar)
http://www.honda-tech.com/zerothread?id=1543394
ALL EBAY TURBO INFORMATION:
http://www.honda-tech.com/zerothread?id=1749857
ARP Head Stud TQ specs
http://honda-tech.com/showthread.php...8#post37569630
Adjusting Valve Lash (thanks to OMG THE GOGGLES)
http://honda-tech.com/showthread.php?t=3213442
How to install & assemble P.T.F.E & Teflon Braided AN Hose (Thanks to OMG THE GOGGLES)
http://honda-tech.com/showthread.php?t=3220511
Rory Breaker is offline   Reply With Quote
Old 01-19-2005, 12:33 AM   #2
TeStUdO's Avatar
Default Re: ***Forced Induction Forum FAQ*** (TeStUdO)
http://www.honda-tech.com/zerothread?id=109160 -oil return line setup
http://www.honda-tech.com/zerothread?id=114490 -oil return line parts
http://www.honda-tech.com/zerothread?id=71999 -where to weld oil return
http://www.honda-tech.com/zerothread?id=119100 -oil return line
http://www.honda-tech.com/zerothread?id=119539 -oil pan welding
http://www.honda-tech.com/zerothread?id=119715 -oil pan welding
http://www.honda-tech.com/zerothread?id=118687 -oil grade to use
http://honda-tech.com/showthread.php?t=3192726 -Oil Grade discussion
http://www.honda-tech.com/zerothread?id=118694 -ft for oil feed line
http://www.honda-tech.com/zerothread?id=118807 -oil feed line
http://www.honda-tech.com/zerothread?id=119681 -oil feed line
http://www.honda-tech.com/zerothread?id=93550 -part for oil feed line
http://www.honda-tech.com/zerothread?id=114436 -where to buy brass t for feed line
http://www.honda-tech.com/zerothread?id=126335 -oil t question
http://www.honda-tech.com/zerothread?id=125438 -another place to buy oil lines
http://www.honda-tech.com/zerothread?id=131447 -oil feed line an/npt connector ?
http://www.honda-tech.com/zerothread?id=134078 -feed diagram
http://www.honda-tech.com/zerothread?id=133948 -oil bpst fitting again
http://www.honda-tech.com/zerothread?id=144586 -oil feed line restrictor
http://www.honda-tech.com/zerothread?id=155510 -oil leaks
http://www.honda-tech.com/zerothread?id=158018 -oil feed 3' better
http://www.honda-tech.com/zerothread?id=156571 -oil pan bolts
http://www.honda-tech.com/zerothread?id=170223 -oil pressure readings
http://www.honda-tech.com/zerothread?id=168084 -oil feed fitting
http://www.honda-tech.com/zerothread?id=131450 -oil feed diagram
http://www.honda-tech.com/zerothread?id=195068 -oil pressu
http://www.honda-tech.com/zerothread?id=364948 -BSPT and NPT AN explanation. ***
http://www.honda-tech.com/zerothread?id=365360 -install of walbro 255lph EF
http://www.honda-tech.com/zerothread?id=122635 -drag 3 (to) coolant line?
http://www.honda-tech.com/zerothread?id=116891 -closed loop turbo info
TeStUdO is offline   Reply With Quote
Old 01-19-2005, 12:33 AM   #3
TeStUdO's Avatar
Old 01-19-2005, 12:34 AM   #4
TeStUdO's Avatar
http://www.honda-tech.com/zerothread?id=118885 -place to buy aem fpr
http://www.honda-tech.com/zerothread?id=122590 -(installing) aeromotive fuel regulator
http://www.honda-tech.com/zerothread?id=86051 -removing/installing intank fuel pump
http://www.honda-tech.com/zerothread?id=120889 -profec b install
http://www.honda-tech.com/zerothread?id=116651 -Radiator fans
http://www.honda-tech.com/zerothread?id=119819 -diff between mechanical/electrical gauges
http://www.honda-tech.com/zerothread?id=117513 -turbo XS boost controllers and tial wastegates
http://www.honda-tech.com/zerothread?id=122396 -block guard
http://www.honda-tech.com/zerothread?id=107030 -rc 440 injector polarity
http://www.honda-tech.com/zerothread?id=82211 -rc 440 after hondata install
http://www.honda-tech.com/zerothread?id=121452 -aeromotive fpr part #
http://www.honda-tech.com/zerothread?id=125639 -hks ssbv clip
http://www.honda-tech.com/zerothread?id=153531 -more hks bov install
http://www.honda-tech.com/zerothread?id=125852 -carsound cat part #
http://www.honda-tech.com/zerothread?id=92570 -turbo timer relay
http://www.honda-tech.com/zerothread?id=128321 -turbo timer wiring
http://www.honda-tech.com/zerothread?id=132485 -radius rods
http://www.honda-tech.com/zerothread?id=63095 -rear seat removal
http://www.honda-tech.com/zerothread?id=133644 -injector fitment
http://www.honda-tech.com/zerothread?id=104940 -thermal to cat issues
http://www.honda-tech.com/zerothread?id=136680 -egt guage stuff
http://www.honda-tech.com/zerothread?id=137223 -which runner to tap for egt
http://www.honda-tech.com/zerothread?id=55987 -aem fpr against strut bar
http://www.honda-tech.com/zerothread?id=139706 -tools to carry
http://www.honda-tech.com/zerothread?id=140003 -base fuel map
http://www.honda-tech.com/zerothread?id=140774 -bleeding coolant
http://www.honda-tech.com/zerothread?id=156073 -js safeguard
http://www.honda-tech.com/zerothread?id=168470 -js safeguard, who is using
http://www.honda-tech.com/zerothread?id=160428 -summit part
http://www.honda-tech.com/zerothread?id=170160 -9psi, raise static fuel + retard timing
http://www.honda-tech.com/zerothread?id=170821 -wires to tap for guages
http://www.honda-tech.com/zerothread?id=171397 -c clamp pliers for hks bov
http://www.honda-tech.com/zerothread?id=171314 -EGT temps
http://www.honda-tech.com/zerothread?id=166449 -vacuum sources
http://www.honda-tech.com/zerothread?id=175335 -assembling an fittings
http://www.honda-tech.com/zerothread?id=176725 -oem fan clearance - move to right
http://www.honda-tech.com/zerothread?id=193263 -greddy profec b
http://www.honda-tech.com/zerothread?id=85987 -installing rc injectors
http://www.honda-tech.com/zerothread?id=106033 -matching wires rc injectors
http://www.honda-tech.com/zerothread?id=133644 -fitment of rc injectors
http://www.honda-tech.com/zerothread?id=107030 -polarity does not matter
http://www.honda-tech.com/zerothread?id=154935 -once installed
http://www.honda-tech.com/zerothread?id=159623 -tips to install
Old 04-19-2005, 12:55 PM   #6
Moderator in Chief
Muckman's Avatar
Overheating
This is for all the threads I see each day about overheating! If your car is over heating the #1 cause is air in the system.
If you have recently drained and refilled the system then this is almost certainly the answer. Some cars have bleeder valves located near the upper coolant line going into the head. Fill the radiator until coolant starts to pour out of the open bleeder then tighten it up. Cars without this bleeder valve can pull the radiator cap off and warm the car up until coolant reaches the very top of the radiator neck. In either case I le to re bleed the system again after a few miles to make sure the entire system is fully circulated. Some tips include leaving the cabin heater on full to allow full coolant circulation and filling the overfill bottle to its "max" level in-case the system needs to draw in more coolant. http://www.honda-tech.com/zerothread?id=140774
Other common causes are a bad thermostat, radiator fan isn't kicking on or is inadequate. And in the most extreme case, a bad head gasket will cause overheating as super hot combustion chamber gases are super heating the coolant.
Muckman is offline   Reply With Quote
Old 05-30-2005, 04:54 PM   #7
gen2integra2001's Avatar
Default Re: ***Forced Induction Forum FAQ*** (Rory Breaker)
nice write up man...this is gonna be realllly handy
gen2integra2001 is offline   Reply With Quote
Old 06-17-2005, 09:42 PM   #8
Joseph Davis's Avatar
Default Re: ***Forced Induction Forum FAQ*** (flip1199)
Quote:
Originally Posted by flip1199
Incomplete + inadequate.
Joseph Davis is offline   Reply With Quote
Old 01-17-2006, 01:03 AM   #9
JDM Vision's Avatar
Default Re: ***Forced Induction Forum FAQ*** (J. Davis)
JDM Vision is offline   Reply With Quote
Old 05-07-2006, 05:50 AM   #10
KeyserSoze's Avatar
Default Re: ***Forced Induction Forum FAQ*** (Bense)
Here is a pretty cool writeup explaining turbocharging, supercharging and basic engine operation. Puts things in laymans terms with nice illustrations as well and a brief history of the turbocharger.
http://www.turbocompressori.ne...s.htm
KeyserSoze is offline   Reply With Quote
Old 05-21-2006, 10:58 AM   #11
alphaek's Avatar
alphaek is offline   Reply With Quote
Old 08-16-2006, 12:27 AM   #12
exim@uu.pp121.net's Avatar
Default Re: ***Forced Induction Forum FAQ*** (alphaek)
Great threads!
exim@uu.pp121.net is offline   Reply With Quote
Old 08-18-2006, 05:30 PM   #13
standinghollow's Avatar
Default Re: ***Forced Induction Forum FAQ*** (exim@uu.pp121.net)
standinghollow is offline   Reply With Quote
Old 08-29-2006, 03:02 PM   #14
needanew1's Avatar
needanew1 is offline   Reply With Quote
Old 11-06-2006, 11:53 AM   #15
low91rex's Avatar
so much info in here!
low91rex is offline   Reply With Quote
Old 11-07-2006, 09:11 PM   #16
sauceja's Avatar
Default Datalogging
I found this helpful with trying to datalog and since I haven't found a more solid source.
http://www.honda-tech.com/zerothread?id=1454695
Also, but I am sure mentioned elsewhere
http://www.xenocron.com
http://www.moates.net
sauceja is offline   Reply With Quote
Old 11-18-2006, 07:46 PM   #17
zzcoupezz's Avatar
Default Re: ***Forced Induction Forum FAQ*** (next21)
what about nitrous?
zzcoupezz is offline   Reply With Quote
Old 12-29-2006, 08:27 AM   #18
Importrev's Avatar
Default Re: ***Forced Induction Forum FAQ*** (zzcoupezz)
Importrev is offline   Reply With Quote
Old 09-27-2007, 06:09 PM   #19
PHILLLLIIPPPP's Avatar
bump
PHILLLLIIPPPP is offline   Reply With Quote
Old 11-23-2007, 04:45 PM   #20
boostede46's Avatar
THANKS EVERY BODY WHO PARTICIPATING IN THIS FORUM IT HAS HELP ME ALOT!!
boostede46 is offline   Reply With Quote
Old 12-10-2007, 11:07 AM   #21
mtownek9's Avatar
the first link under "What is in a turbo kit, what do I need?" is dead.
mtownek9 is offline   Reply With Quote
Old 12-25-2007, 02:33 PM   #22
hondapimpin420's Avatar
great info guys
hondapimpin420 is offline   Reply With Quote
Old 03-27-2008, 12:51 PM   #23
95greenlude's Avatar
Default Re: ***Forced Induction Forum FAQ*** (hondapimpin420)
HOW TO INSTALL A WET NITROUS SYSTEM by: 95greenlude
http://www.honda-tech.com/zerothread/2261379
95greenlude is offline   Reply With Quote
Old 04-27-2008, 11:35 AM   #24
LSej1's Avatar
Good to know info
LSej1 is offline   Reply With Quote
Old 05-26-2008, 07:11 PM   #25
96civic_hb's Avatar
Default Re: ***Forced Induction Forum FAQ*** (LSej1)
96civic_hb is offline   Reply With Quote
88-91 CRX/EF Civic Frequently Asked Questions (FAQs) Tyson Honda CRX / EF Civic (1988 - 1991) 8 02-08-2017 01:31 PM
► ALL GEN Integra [FAQ] - DIY,Write ups, How to, etc Jimmy Acura Integra 81 10-28-2016 10:43 AM
Turbo Honda/Acura Pics/Theory/Installation/Discussion/FAQ DirtyDA9 Forced Induction 901 10-27-2014 11:05 PM
All Motor forum [FAQ] Jimmy All Motor / Naturally Aspirated 6 02-22-2012 02:31 PM
► 1990-2002 Accord FAQ -RedneckDave- Honda Accord (1990 - 2002) 0 06-19-2006 10:31 AM
Tags
afc, avcr, boost, creep, explained, feed, fittings, h22, hack, holset, honda, install, kit, line, manifold, obx, oil, safeguard, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
