***The Official JRSC Thread***
Old 02-26-2006, 10:01 PM
  #2501
BiG Chris's Avatar
Default Re: (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">anyone wana sell me a 3.8 pulley?</TD></TR></TABLE>
I got a extra 3.8" pulley but its for a d series
Old 02-26-2006, 10:06 PM
  #2502
Timmay's Avatar
Default Re: (BiG Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris &raquo;</TD></TR><TR><TD CLASS="quote">I got a extra 3.8" pulley but its for a d series</TD></TR></TABLE>
i wonder how much of a difference it makes?
Old 02-26-2006, 10:16 PM
  #2503
hinds90's Avatar
whats you guys estimate on what a jdm gsr with 8 psi and i/e/h wll put down on the dyno. I know there many factors to consider but i'm just looking for an educated guess.
Old 02-26-2006, 10:22 PM
  #2504
Timmay's Avatar
Default Re: (hinds90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">whats you guys estimate on what a jdm gsr with 8 psi and i/e/h wll put down on the dyno. I know there many factors to consider but i'm just looking for an educated guess.</TD></TR></TABLE>
200-230whp
Old 02-26-2006, 10:28 PM
  #2505
hinds90's Avatar
do you think the high boost jrsc kit is worth it.
Old 02-26-2006, 10:32 PM
  #2506
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">do you think the high boost jrsc kit is worth it.</TD></TR></TABLE>
no, its stuff you can buy for cheaper anywhere else
Old 02-26-2006, 11:35 PM
  #2507
mgro's Avatar
Default Re: BLOWER RPM (Veris)
Good info Veris, thanks for the contribution!
I was planning to install a CRV pulley on my new motor, thinking that it would be better to increase the accessory drive speed then to decrease the blower snout pulley diameter. However, the PS drive section of the CRV pulley is quite a bit larger then the stock B16 pulley. This can be solved by installing a larger PS pump pulley. I found 2 companies that carry accessory underdrive pulleys: Unorthodox racing and AEM. AEM is the only of the two that makes larger-then-stock accessory pulleys (Unorthodox supplies lighter but stock sized accessory pulleys in combination with a special crank pulley, which is useless in this case). Unfortunately AEM doesn't appear to specify the ratio of underdrive for their PS pulley!
- Does anyone know the underdrive ratio (or diameter) of the AEM PS pulley?
- Are there more companies that make larger-then-stock PS pump pulleys?
Thanks!
Mark.
Old 02-26-2006, 11:47 PM
  #2508
Timmay's Avatar
Default Re: BLOWER RPM (mgro)
hey are any of you B-series guys running catch can setups??? just curious how you are hooking them up?
Old 02-27-2006, 04:26 AM
  #2509
Gojira D.O.T's Avatar
i have an aem ps pulley on my car ill measure it later today,im not sure if aem uses different sizes for diff engines, mine was for the stock single cam but i swapped it to the ps pump on my b16,there are deffinetly different sized oem pulleys as well
Old 02-27-2006, 04:28 AM
  #2510
rmcdaniels's Avatar
Default Re: BLOWER RPM (Timmay)
cool , just when you find some spare time that would rock</TD></TR></TABLE>
I found it, e-mail me a shipping address.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgro &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks!
Mark.</TD></TR></TABLE>
Mine has an OBX pulley on it. The pulley is a bit less than 6.5" (measured on the outside edge, where the grooves are is a bit smaller).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">hey are any of you B-series guys running catch can setups??? just curious how you are hooking them up?</TD></TR></TABLE>
I run an Endyn catch can. It's hooked up to the two fittings on the back of the block.
Old 02-27-2006, 06:06 AM
  #2511
elpiar's Avatar
Default Re: BLOWER RPM (rmcdaniels)
Anyone has the correlation between the blower rpm and the psi it yields?
Old 02-27-2006, 06:08 AM
  #2512
Veris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgro &raquo;</TD></TR><TR><TD CLASS="quote">G- Does anyone know the underdrive ratio (or diameter) of the AEM PS pulley?</TD></TR></TABLE>
I just happened to have on right here...
~5"
Old 02-27-2006, 06:21 AM
  #2513
Veris's Avatar
Default Re: BLOWER RPM (elpiar)
ESTIMATES
For a 1595cc engine.
CRANK/BLOWER/RPM/PSI
GSR / 4.2 / 10,900 / 7
GSR / 4.0 / 11,550 / 8
GSR / 3.8 / 12,000 / 9
CRANK/BLOWER/RPM/PSI with 12% alternator overdrive
GSR / 4.2 / 12,200 / 9.4
GSR / 4.0 / 12,800 / 10.5
GSR / 3.8 / 13,500 / 11.7
For a 1979cc engine.
GSR / 4.2 / 10,900 / 5.7
GSR / 4.0 / 11,550 / 6.4
GSR / 3.8 / 12,000 / 7.3
GSR / 4.2 / 12,200 / 7.6
GSR / 4.0 / 12,800 / 8.4
GSR / 3.8 / 13,500 / 9.4
Old 02-27-2006, 06:27 AM
  #2514
Veris's Avatar
ESTIMATES
1595cc
CRV / 4.2 / 13,700 / 12
CRV / 4.0 / 14,400 / 13.5
CRV / 3.8 /15200 / 14.8
CRANK/BLOWER/RPM/PSi with 12% alternator overdrive
CRV / 4.2 / 15,400 / 15
CRV / 4.0 / 16,200 / 16.5
CRV / 3.8 / 17,000 / 18.1
1979cc
CRV / 4.2 / 13,700 / 9.8
CRV / 4.0 / 14,400 / 10.8
CRV / 3.8 /15200 / 12
CRV / 4.2 / 15,400 / 12.2
CRV / 4.0 / 16,200 / 13.3
CRV / 3.8 / 17,000 / 14.5
Old 02-27-2006, 06:30 AM
  #2515
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Veris &raquo;</TD></TR><TR><TD CLASS="quote">ESTIMATES
You mean a 1779cc engine? B18C1?
Old 02-27-2006, 06:35 AM
  #2516
elpiar's Avatar
Is the manifold for B18B and B18C1 the same?
Old 02-27-2006, 06:38 AM
  #2517
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">Is the manifold for B18B and B18C1 the same?</TD></TR></TABLE>
Completely different.
Old 02-27-2006, 07:17 AM
  #2518
BiG Chris's Avatar
i wonder how much of a difference it makes?</TD></TR></TABLE>
the spacer from the snout of the blower to the nut on the pulley is cut and used in front of the where you actually bolt it place
Old 02-27-2006, 08:02 AM
  #2519
theres a pulley on ebay right now
Old 02-27-2006, 12:15 PM
  #2520
Veris's Avatar
You mean a 1779cc engine? B18C1?</TD></TR></TABLE>
Nope, I mead 1979. 85mm gsr (2L)
Old 02-27-2006, 01:59 PM
  #2521
elpiar's Avatar
so what would the boost be for GSR stock displacement?
Old 02-27-2006, 03:27 PM
  #2522
Veris's Avatar
1779cc
GSR / 4.2 / 10,900 / 6.3
GSR / 4.0 / 11,550 / 7.2
GSR / 3.8 / 12,000 / 8.1
GSR / 4.2 / 12,200 / 8.4
GSR / 4.0 / 12,800 / 9.4
GSR / 3.8 / 13,500 / 10.5
CRV / 4.2 / 13,700 / 11
CRV / 4.0 / 14,400 / 12
CRV / 3.8 /15200 / 13.2
CRV / 4.2 / 15,400 / 13.6
CRV / 4.0 / 16,200 / 14.8
CRV / 3.8 / 17,000 / 16.2
Old 02-27-2006, 03:45 PM
  #2523
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Veris &raquo;</TD></TR><TR><TD CLASS="quote">1779cc
CRV / 3.8 / 17,000 / 16.2</TD></TR></TABLE>
im confused here, so crv crank pulley with 4.0 nose =12lbs of boost?
also whats teh 12% overdrive thing???
Old 02-27-2006, 04:18 PM
  #2524
xerox445's Avatar
gsr + 4.2 + crv pully is 11 pounds? i dunno about that, can anyone confirm?
Old 02-27-2006, 04:46 PM
  #2525
Veris's Avatar
also whats teh 12% overdrive thing???</TD></TR></TABLE>
Alternator stepper puller. re: endyn/mvm
Quick Reply: ***The Official JRSC Thread***
