VSS wiring question. Pin A18
Old 01-17-2014, 08:13 PM
13173's Avatar
Default VSS wiring question. Pin A18
I have an auto K24A1 harness mated to a K24A1, but I am using a base model RSX 5 speed tranny. I swapped this it into an EF and I am also using a Ktuned conversion harness along with Kpro. So far the car has been started with this wiring combination. Now I am working on addressing the VSS situation. The auto harness is not pinned at A18 for the VSS signal. I got some diagrams from factory service manuals and did a little research. I just want to get some other opinions about my options here.
The auto CRV transmission had two speed sensors for the input and output shaft. Both connectors are 3 wire connectors, but will not fit on a base model RSX speed sensor, however; one will stretch to the location of the VSS so that is the wiring I want to use. I will just have to repin those wires to a connector that will work on the VSS. According to the manuals the wires for the auto speed sensor work the same as with any manual transmission VSS. There is a power, ground, and signal wire. It seems that the signal wire feeds the ECU a voltage of no more than 5 volts when the transmission is turning so that should work, right? I should be able to take the signal wire and swap it from the original location on the harness which is pin C15 over to pin A18 like that of a manual harness, right?
Would there be any problems with this?
Old 01-18-2014, 07:30 AM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Default Re: VSS wiring question. Pin A18
What exactly is your concern? If depinning an ECU is OK? Then of course it is fine...
Old 01-18-2014, 07:37 AM
13173's Avatar
Yeah, I know I can depin an ECU.
95coupeb
04-06-2010 07:27 AM
xalents23
06-03-2008 07:59 PM
Jdm91Teg
07-18-2005 01:18 PM
turboed4life
12-13-2004 04:20 PM
Quick Reply: VSS wiring question. Pin A18
