P0685 Code Need Help!!!
Old 07-20-2009, 04:51 PM
ATLTSX's Avatar
Default P0685 Code Need Help!!!
I have a 2004 Acura TSX. I just recently went turbo. I'm running Hondata Kpro (Consides of Reflashed TSX ECU and RSX Type S ECU). Everything was running fine. A couple days ago when I was going into boost i got a CEL. The code that came up was P0685. This is ECM/PCM Power Relay Control Circuit/Open. Kpro is not showing any CEL so it has to be in the TSX ECU. I took the TSX ECU out to make sure that the Board wasn't burnt. Plugged everything back in and i got 1 run where it ran fine. Came up to the next light and it did it again.
Any thoughts? I'm trying to get this fixed to make it to IA.
Thanks.
Old 10-03-2016, 05:04 AM
bansell's Avatar
Default Re: P0685 Code Need Help!!!
Very old, but did you ever figure this one out?
SolScifen
05-19-2013 11:35 AM
jltucker31
03-09-2009 03:50 PM
Brewer
07-07-2004 01:49 PM
racerxadam
01-13-2002 08:37 PM
Quick Reply: P0685 Code Need Help!!!
