Oil level issues
Old 02-15-2014, 02:18 PM
DjDoc6's Avatar
Default Oil level issues
Ey guys im having a slight issue. Last week my dip stick showed i had zero oil. Not a drop on the stick! And that was after my car was sitting for two hours. I needed to change my oil pan gasket anyway so i droped my oil pan and there was atleast 2-3quarts in the pan. Left me a little conffused. Anyway i changed the gasket and oil filter and out in 4 1/2 quarts of oil in the car. Its been 4 days i decided to check my dip stick and there is just a little on the stick right below the first circle. Im so confused i know im not leaking 4 1/2 quarts of oil.
Engine : B18C5
DjDoc6 is offline
Old 02-15-2014, 02:19 PM
DjDoc6's Avatar
My buddy also have a b18c5 in his car i looked we have the same size oil pan and same size dip stick. Im really mind fu*k3d on this
DjDoc6 is offline
Old 02-15-2014, 03:14 PM
DjDoc6's Avatar
Anything?
DjDoc6 is offline
Old 02-15-2014, 04:16 PM
preludeNApower's Avatar
Default Re: Oil level issues
My friend, the stick does not go to the bottom of the pan. The bottom of the stick usually indicates ABOUT 2 quarts low.
preludeNApower is offline
Old 02-15-2014, 04:18 PM
Miguel613ekb18c's Avatar
Ur probly burning oil the by piston rings or valve stem seals if ur not leaking though your oil pan or main seal
Miguel613ekb18c is offline
Old 02-15-2014, 05:43 PM
DjDoc6's Avatar
I know im leaking a little at the PVC but in four days i dont believe i could have burned two quarts or leaked two quarts thats a **** ton.
I replaced the dizzy o ring becuase i was leaking there. Oil pan gasket, valve cover gasket, cam seal.
DjDoc6 is offline
Old 02-23-2014, 06:50 PM
How many clicks have u driven in 4 days, I've seen Hondas burn oil until there's no oil left on the dip stick 500 km of driving
Old 02-24-2014, 05:44 PM
moderator emeritus
98vtec's Avatar
this is the engine management and tuning section. you posted in the wrong section.
this is for tuning software help and engine computer help.
98vtec is offline
Old 02-24-2014, 05:46 PM
moderator emeritus
98vtec's Avatar
the top mark represents full. the bottom mark represents 1 quart low.
98vtec is offline
Uljima
06-03-2015 06:17 AM
bjones6215
09-10-2013 07:55 PM
tw1nny03
03-03-2008 05:29 AM
uEDarkShadow
07-13-2006 07:02 PM
swlabhot
08-21-2003 04:38 AM
Quick Reply: Oil level issues
