Need Help, O2 sensor problem
Old 06-04-2008, 12:14 PM
LS1_Nicky's Avatar
Default Need Help, O2 sensor problem
hey guys, a buddy of mine has a 2000 Honda Accord SE, 2.3L i believe-it was throwing 2 codes that i pulled with my reader--P1166 and P1167, I changed out the O2 sensor but its still throwing the 1167 Code which says something about the Heater circuit for the O2 sensor, ive checked fuses an they all look okay, im not sure what to look for next, i dont know very much about honda motors so i thought i would come in an ask the experts. thanx
Old 06-04-2008, 07:56 PM
LS1_Nicky's Avatar
man, only 13 views?? this site is dead
Old 06-05-2008, 06:17 AM
downest's Avatar
Default Re: (LS1_Nicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS1_Nicky &raquo;</TD></TR><TR><TD CLASS="quote">man, only 13 views?? this site is dead</TD></TR></TABLE>
Your question has nothing to do with tuning or EMS.
Old 06-05-2008, 06:41 AM
LS1_Nicky's Avatar
Default Re: (downest)
thanks captain obvious, but since you guys don't have a general maintanence section this seemed like the best place to go since i figured i'd find some experts on how some of these sensors work an what controls them, guess not-thanx anyway
Old 06-05-2008, 09:53 PM
raidacaipo's Avatar
same problem.. Im still tryin to figure out why im getting a cel for the o2 sensor and I even tried replacing them and it still comes back.. but then again they were old sensors.. Im ordering a new one right now from ebay.. denso
Old 06-07-2008, 05:28 PM
likwidchz's Avatar
well if you take your o2 sensor out and measure the resistance between the 2 black wires "that's the heater circuit" and its open that means that its bad, also if there is a resistance between the 2 black leads on the questionable o2 sensor "which there should be" compare this with the values of a working oem o2 sensor and see if the resistance is the same. or close.
if that stuff checks out then.. check the ecu circuitry
the 2 black wires that go to the 02 sensor come from the ecu "whatever obd2 pin this is should be something like 02 sensor heater control" and the other should be +12 with key in the 2 position.
the 2 black wires coming from the ecu and +12 have no polarity so switching them isn't going to cause any problems.
Hope that helps.
Old 06-07-2008, 06:29 PM
GhostAccord's Avatar
Default Re: (likwidchz)
I posted a O2 Heater sensor circuit trouble shooting chart in a thread for LS1_Nicky in the Accord forum.
Click Here! if you want to check it out.
claytonsmith
10
05-16-2006 12:01 PM
apok
05-16-2005 09:52 PM
cu3tip
10-18-2004 08:26 PM
scrubachu
07-31-2001 08:58 AM
scrubachu
07-30-2001 05:12 PM
Quick Reply: Need Help, O2 sensor problem
