My first basemap h22 - Honda-Tech
Old 12-15-2011, 11:58 AM   #1
Default My first basemap h22
hey all i just got crome and was trying to retune and adjust wat i could out of the stock h22 basemap a little tweeks in low/high cams etcetc
the setup includes
jdm h22 blacktop(10.6.1CR)
manual m2a4 trany
0.20head shave(assuming the car should be around 10.8.1 or so)
4-2-1 header 2.5inch piping and exhaust
msd ignition with blaster
removed the IABS
a very mildy mild headport and polish
the guy from whome i got the car(allmost fogot,its a ED3 sedan) had this setup with an auto p13-j50 ecu(no vtec whatsover too many cells)
i got rid of all the wiring issue+i bought a p08 ecu ill be chipping it tomorrow
am attaching the basemap ill be using for this setup
any help would be acceptd hope am doing good this is my first car and there is no tuner in my city ill have to go 500miles away from my city so please help
SpoonMotorSport is offline   Reply With Quote
Old 12-15-2011, 12:00 PM   #2
Default Re: My first basemap h22
ehh how do you upload bin files
Old 12-15-2011, 12:04 PM   #3
http://forum.pgmfi.org/viewtopic.php?f=40&t=22781
here is where u can download the bin file plz plz plz help me out
Old 12-15-2011, 11:25 PM   #4
mouab18c1's Avatar
Do you have a wideband?
There is a DIY on Crome on xenocron.com
mouab18c1 is offline   Reply With Quote
Old 12-16-2011, 12:38 AM   #5
not yet i have bought one and ill be getting the shipment in like 3-4days
am not planning on a onboard tune with extreme hulog and ostrich but i just wanted to burn a map for this setup of mine the thing that i fail to understand is that i downloaded a p13 basemap stock one and i have this map which i got from a buddy of mine p30 base for h22 both are hella different from each other i dont know why?
the stock one shows like 29%duty cycle at wot and the other one shows like 106% the whole look of the map is different and both of the maps state for stock h22? why is that?
Old 12-16-2011, 01:56 AM   #6
mouab18c1's Avatar
They are different because one is the stock p13 base and the other is a p30 base. That will make a difference. They used the p30 base to eliminate the IAB's.
This is a stock p13 basemap I downloaded off of PGMFI.ORG
Injector duty cycle at highload
Old 12-16-2011, 04:08 AM   #7
yeah man exactly this is the same map see how different both of them are? so what do u prefer me to tune? i mean should i get the p30 base for my chip or should i get the same as above and just add a bit timing and add some fueling(increase a bit of injector duty cycle under load) and till i get my wideband and romulator i start tuning?
i mean if i add timing and adjust fuel in the p13 base i would be fine running my setup? right?
Old 12-16-2011, 10:44 AM   #8
mouab18c1's Avatar
I would make a new basemap using the p30 base and p13 maps. I also wouldnt touch anything else without a wideband installed or the proper tuning skills.
Old 12-16-2011, 11:01 AM   #9
ok i just got a p08 ecu ready to chip
so u want me to get started with a p30 base and copy all the p13 tables(igi/fuel) and paste them to the p30? same low duty cycles? obviously after the wideband ill be getting it riched to hell and start lean it afterwards
Old 12-16-2011, 11:57 PM   #10
mouab18c1's Avatar
You don't need to worry about the duty cycles. Just copy and paste the fuel and ign maps onto the p30 base. Follow the DIY on xenocron.com
Old 12-19-2011, 07:38 AM   #11
Quote:
I take it you dont know that the crome p13 code is not complete. Take a look at the rest of the p13 and tell me if you think its fine to copy and paste thse values.
q16racer is offline   Reply With Quote
Old 12-19-2011, 03:23 PM   #12
Quote:
Timing is timing...so no issues there if you make sure you are using the same Load and RPM scalars. For safety in a basemap, take 2-6 degrees out of ANYTHING you find...stock or internet gangster maps and you'll be good until you can get a dyno tune.
The fuel values are raw, and again can be copied over if the RPM and LOAD scalars are the same. Im not exactly sure if the GSR or P13 fuel routines in stock code are similar...so that might be a big difference, and then you have to account for the difference in injector size. I believe as long as you figure in the injector size differences after you copy/paste...and then add 10% fuel as a cushion for safety...it should run ok.
xenocron is offline   Reply With Quote
Old 12-19-2011, 03:31 PM   #13
The last p13 crome base code i saw was incomplete.
Old 12-22-2011, 05:58 AM   #14
nikolai.'s Avatar
You can't use p13 bin fuel tables in p30 base code. The tables aren't used in the same way. Like Xenocron said, you can use the same timing tables as long as the rpm and load scalars are the same. Your best bet for the fuel is to use the fuel from someone else's h22 basemap (that uses the same scalars) and tune the fuel with a wideband. If for either the fuel or timing tables, the scalars that you are pulling from aren't the same as what's applied in your own map, then you can interpolate the new values to give you a good starting point.
nikolai. is offline   Reply With Quote
Old 12-24-2011, 09:28 PM   #15
I'm Huge In Japan
VegasInvasion's Avatar
I have working P13 ROMs, PM me.
VegasInvasion is offline   Reply With Quote
Old 12-25-2011, 11:46 AM   #16
car is running on chipped p08 ecu with the h22 basemap i downloaded from pgfmi.org :S it was rich so as i leaned it a bit - its running fine now but i still dont get the part of roms? what does this guy above me means by i have p13 roms roms=basemap?
Old 12-25-2011, 11:48 AM   #17
Read only memory.
Old 12-25-2011, 04:30 PM   #18
siregcivic's Avatar
i have a really good h22 basemap i can send you when i get home, your car will be faster on it i guarantee ive been through a few of those pgmfi basemaps and they are no good.. i made mine from a hondata s300 map and copied it over to crome
lmk if you want it...
timing is good might be a little rich but you will only know if you have a wideband its close
siregcivic is offline   Reply With Quote
Old 12-26-2011, 12:31 AM   #19
mouab18c1 - thankhyou so much for pushing me on the right path with some basics
VegasInvasion - thankhyou so much sir
nikolai - yeah i will look up on that appreciated
xenocron - you're the man!
thankhyou all honda-tech members for such tender replies God bless!
Old 12-26-2011, 03:57 AM   #20
why do people say p30 base p72 base come options are available in p30 which arnt on p72 like this guy abv said p13 bin is incomplete(then why dont everyone go with p30?)
Old 12-26-2011, 07:05 AM   #21
GhostAccord's Avatar
ROM (Read only memory) would actually be the physical chip that you load your data or software binary file (.bin, .cal etc etc...) onto in the ECU. Actually if it is a chipped ECU it's more than likely that it is an E2PROM ((E)EPROM or EPROM = Electrically Erasable Programmable Read-Only Memory). However, It seems as though a lot of Tuners/Honda owners simply use the word ROM to mean the basemap/or tuned binary file. Not sure why????
GhostAccord is offline   Reply With Quote
Old 12-27-2011, 01:19 PM   #22
hmmm means p08 map on p30 bin/code= p30 ecu chipped with p08 basemap
.......................p13 map on p08 bin/code=p08 chipped ecu with p13 mapps right???
Old 12-27-2011, 01:46 PM   #23
Edit...... To avoid confusion. The term ROM when referring to a P30, P72 ROM when starting in Crome. Is referring to the code base that is being used on that particular ROM chip.
A P08 map (.bin file) copied into a P30 ROM (Code) = P30 ECU with P08 tune.
There is no such thing as P08 ROM in Crome
If you have a chipped P08 and you want an H22 basemap using Crome. You would have to copy and paste a P13 (H22A).bin file into an open P30/P72 ROM. Basically turns your P08 into a P30/P72 ECU running a P13 (H22A) basemap/tune.
Old 12-27-2011, 07:43 PM   #24
I'm Huge In Japan
Quote:
Since Hondata, CROME, Neptune etc. are all ROM editors, it's used as a generic term for the files of various extensions.
The files I was offering are P13 based, they actually work in the P13 ECU (I saw the picture, jumped to conclusions). PS check your PGMFI post.
Old 12-28-2011, 08:36 AM   #25
i get it now thnx a ton ghostaccord
No Vtec after H-tune Basemap chip install Stevieh62000 Engine Management and Tuning 2 09-01-2016 12:26 PM
H22 basemap Cho0se Engine Management and Tuning 1 01-05-2014 03:05 PM
OBD1 H22A cyl 1 misfire??? Greenflashlight Honda Accord (1990 - 2002) 2 04-25-2012 08:14 PM
Code 13 BARO - atmospheric pressure sensor. What does this mean please? djnikko Tech / Misc 2 01-13-2010 08:23 PM
D15B T3 7-10 PSI Basemaps turboed-single-cam Forced Induction 1 10-28-2007 09:34 PM
Tags
38, base, basemap, ecu, good, h22, h22a, honda, iabs, integra, ls, map, remove, stock, tech, tuning, wot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
