Mode 6 Data Definitions for OBD II online - Honda-Tech
Old 04-02-2011, 01:12 PM   #1
Default Mode 6 Data Definitions for OBD II online
Listers,
While researching another problem, I found the following links which will provide you a way to make sense of the gobbildy **** of Mode 6 on your scan tool. The first ones relate to Honda. See
http://www.aa1car.com/library/honda_mode06.pdf
http://www.d-tips.com/General/Mode$06/
http://service.gm.com/gmspo/mode6/index.html
Hopefully, this will save someone some time looking for this info.
Chaz
PS For some strange reason, the second link will not format properly. Simply copy and paste it into your browser's address window.
Last edited by chaztuna; 04-02-2011 at 01:17 PM. Reason: edited the 2nd link to function properly
chaztuna is offline   Reply With Quote
Learn me how to multimeter #ugonlearntoday $amGD3 General Discussion and Debate 41 02-25-2015 09:31 AM
Can't deside on an exhaust here are some sound clips RiceKillinSI Honda Civic / Del Sol (1992 - 2000) 61 04-27-2011 09:18 AM
High Mileage curbed rim fix (write up) allmotorSOHC16 Honda / Acura 16 01-04-2007 06:46 PM
92 dx hb 2178lbs vs. 92 dx sedan 2275lbs drifter Honda Civic / Del Sol (1992 - 2000) 13 11-20-2002 09:32 AM
ATTN SIINSI Brewer Honda Civic / Del Sol (1992 - 2000) 3 01-25-2002 06:26 PM
Tags
06, 2002, 2011, accord, data, definitions, honda, library, mode, obd2, obdii, read, scan, specific, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
